[gdal-dev] problem on function "OGR_FD_GetName"
Chaitanya kumar CH chaitanya.ch at gmail.com
Thu Jun 17 04:37:27 EDT 2010
Randy,
I think you need to fiddle with the preprocessor definition
S57_BUILTIN_CLASSES during compilation. (
http://trac.osgeo.org/gdal/browser/trunk/gdal/ogr/ogrsf_frmts/s57/s57classregistrar.cpp
I didn't work with S-57 format, so I don't know any more than you.
On Thu, Jun 17, 2010 at 1:51 PM, randy <randyqiuxy at hotmail.com> wrote:
> Hi Peter,
> Thanks for your response!
> >     I do not use s57 data, however I have written a number of programs
> which use
> > OGR_FD_GetName ... and it has always returned the feature name, if set,
> or null
> > for me.  Feature, as opposed to Layer, names seem quite uncommon,
> however;
> > although I generally set feature names when creating data objects, I have
> rarely
> > encountered them on input from other sources.  I have never investigated
> whether
> > this is a failure in OGR to transmit the name or whether my presumption
> that
> > there was no name to transmit is correct.
> My problem is a little odd. In my Ubuntu9.04 OS,my application works well,
> however,
> in my new 10.04 LTS OS, I rebuilt GDAL and my application,then it refused
> to work.
>  So in my last e-mail,I asked Chaitanya whether the environment variable
> did anything bad.
> > I'm not sure how much that helps,
> Yes,I appreciate anything you said above including experience,suggestion...
> Best regards,
> Randy
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100617/132d5fd7/attachment.html
