[gdal-dev] I am trying to run gdal_polygonize.py and I get the
following error: gdal.Polygonize() not available.
Frank Warmerdam
warmerdam at pobox.com
Tue Jun 22 14:40:09 EDT 2010
John Mitchell wrote:
> Hi,
> I am trying to run gdal_polygonize.py and I get the following error:
> gdal.Polygonize() not available. You are likely using "old gen"
> bindings or an older version of the next gen bindings.
> Anyone have any idea how I can get gdal_polygonize to run within FWTools 2.4.7?
> Below is the command and error from the command line.
John,
I'm afraid that polygonize support is not available with FWTools.
You could use OSGeo4W or other more modern GDAL binaries.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
