Re: [gdal-dev] Raster/vector intersections in PostGIS WKT Raster
Ivan Lucena
ivan.lucena at pmldnet.com
Tue Jun 29 14:30:39 EDT 2010
Christian,
How did you added support for Oracle GeoRaster on GeoTools/GeoServer? Did you use the Oracle GeoRaster Java API or GDAL? Is that available?
I am looking forward to use it.
Regards,
Ivan
> -------Original Message-------
> From: christian.mueller at nvoe.at
> To: Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
> Cc: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
> Subject: Re: [gdal-dev] Raster/vector intersections in PostGIS WKT Raster
> Sent: Jun 29 '10 11:46
> Hi, superb job. Congratulations.
> I am a geotools/geoserver developer and one of my jobs is fetching
> image tiles or the corresponding pyramid tiles from jdbc data
> sources. Some weeks ago, I added support for Oracle Georaster and I
> want to support WKT Georaster too.
> wktraster makes it quite simple to achieve this. Is there any database
> layout you recommend. (A table for the image and one for each pyramid,
> or put all the tiles into one table having an attribute "level",.....).
> I have seen "gdal2wktraster.py", is this the recommended way to import
> tiles into postgis ?
> What is the table layout created/needed by this utility ?
> Cheers
> Christian
> Quoting Pierre Racine <Pierre.Racine at sbf.ulaval.ca>:
> > Hi everybody,
> > I'm pleased to announce that you can now do intersections between
> > rasters and geometries very much like you used to do
> > geometry/geometry intersections in PostGIS. For this, PostGIS WKT
> > Raster introduces two new functions to PostGIS:
> > ST_Intersects(geometry, raster, band) and ST_Intersection(geometry,
> > raster, band).
> > As its geometry/geometry sister, ST_Intersects(geometry, raster,
> > band) returns TRUE if the withvalue area of a raster or a raster
> > tile (nodata value are ignored) intersects a geometry and
> > ST_Intersection(geometry, raster, band) returns the geometry/value
> > set of geometries representing the intersection between the geometry
> > and each polygonized group of pixel sharing a same value from the
> > raster and its associated value. Example:
> > SELECT polyid,
> > (ST_Intersection(the_geom, rast)).geom,
> > (ST_Intersection(the_geom, rast)).val
> > FROM my_polygons, srtm_tiled
> > WHERE ST_Intersects(rast, the_geom)
> > or, a bit more complex, but much faster and returning the same result:
> > SELECT polyid, (gv).geom, (gv).val
> > FROM (SELECT polyid, ST_Intersection(the_geom, rast, 1) AS gv
> > WHERE ST_Intersects(rast, the_geom)) foo
> > These functions works with any kind of geometry so you can intersect
> > any road, river, polygons or point layer with your favorite
> > elevation or land cover raster of any resolution and any size. You
> > can also load any number of raster in the database with one command
> > line to constitute a unique table raster coverage of any shape (no
> > matter if your group of raster do not form a rectangular coverage).
> > You will find a complete tutorial on how to use those two new
> > functions here:
> > http://trac.osgeo.org/postgis/wiki/WKTRasterTutorial01. A reference
> > is available here:
> > http://postgis.refractions.net/documentation/manual-svn/RT_reference.html
> > and chapter 13 of "PostGIS in Action" is also a very good
> > introduction to WKT Raster.
> > Compilation and installation info are available in the project home
> > page: http://trac.osgeo.org/postgis/wiki/WKTRaster
> > These features are the result of two years of collaboration between
> > many people and companies interested in bringing raster into
> > PostGIS. I would like to thanks particularly Steve Cumming who
> > initially made all this possible, Sandro Santilli who wrote the base
> > code, Mateusz Loskot who wrote the Python loader, Jorge Arevalo who
> > wrote the GDAL driver and ST_DumpAsPolygons(), Regina and Leo Obe
> > who are doing so many things and believed in the project from the
> > beginning by adding a chapter about WKT Raster in "PostGIS in
> > Action" and also David Zwarg who wrote most of the setter functions.
> > This is the first step toward a first complete raster/vector
> > analysis and manipulation SQL API. We hope to make of PostGIS with
> > WKT Raster the most powerful and complete GIS analysis and
> > manipulation high level language ever (!!!). WKT Raster should
> > normally be totally integrated into PostGIS in PostGIS release 2.0.
> > Upcoming functions should include ST_Reclass, ST_Clip, ST_AsRaster,
> > ST_Resample.
> > Let us know your need and your experience with WKT Raster.
> > Thanks,
> > Pierre Racine
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> This message was sent using IMP, the Internet Messaging Program.
