[gdal-dev] first time gdal-java exception
ahmet temiz ahmettemiz88 at gmail.com
Wed Jun 30 02:52:36 EDT 2010
thank you
No, I didn't know I had to do that.
I looked up the example you gave me.
it contains destroying of drivermanager as gdal.DestroyDriverManager();
but not explicit initializer.
Does "Driver driver = gdal.GetDriverByName(outputFormat);" make initialization ?
regards
2010/6/29 Ivan Lucena <ivan.lucena at pmldnet.com>:
> Hi there.
> Did you initialize the driver manager?
> Example: http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/java/apps/GDALGrid.java#L521
> Regards,
> Ivan
>>  -------Original Message-------
>>  From: ahmet temiz <ahmettemiz88 at gmail.com>
>>  To: gdal-dev <gdal-dev at lists.osgeo.org>
>>  Subject: [gdal-dev] first time gdal-java exception
>>  Sent: Jun 29 '10 13:14
>>  hello
>>  when I  tried gdal-java in first time, I got this exception:
>>  "Exception in thread "main" java.lang.UnsatisfiedLinkError:
>>  org.gdal.ogr.ogrJNI.wkb25Bit_get()I"
>>  here is the code fragment that gives the exception:
>>  Geometry lr1 = new Geometry(ogr.wkbLinearRing, null, null, null);
>>  lr1.AddPoint_2D(0, 0);
>>  lr1.AddPoint_2D(10, 10);
>>  lr1.AddPoint_2D(10, 0);
>>  Geometry pol1 = new Geometry(ogr.wkbPolygon, null, null, null);
>>  pol1.AddGeometry(lr1);
>>  might this exception have to do with my having generated gdal-java
>>  from "rpm" for ubuntu?
>>  do you recommend me another way  to get gdal-java for ubuntu ?
>>  regards
>>  _______________________________________________
>>  gdal-dev mailing list
>>  http://lists.osgeo.org/mailman/listinfo/gdal-dev
