[gdal-dev] enable GEOS support (GDAL/OGR 1.7.1; GEOS 2.3.0;
VB.NET)
toefftoeff1 at gmx.net
Mon Mar 8 14:10:54 EST 2010
Hi Tamas,
thanks a lot for Your reply.
Using Your SDK I was able to track down the compilation problem - swig
did not re-generate all files
and I needed to include an extra GEOS-header directory as follows:
GEOS_CFLAGS = -I$(GEOS_DIR)/capi -I$(GEOS_DIR)/source/headers
-I$(GEOS_DIR)/source/headers/geos -DHAVE_GEOS
Kind regards,
Christoph
> Hi,
> You might wan't to make a test with the packages available at:
> http://vbkto.dyndns.org/sdk/
> All of those gave geos support compiled in.
> By downloading the SDK pacakges your could also compile gdal by
> yourself easily using a VS Command Prompt and type 'nmake gdal' in the
> SDK root directory.
> Best regards,
> Tamas
> 2010/3/5 <toefftoeff1 at gmx.net <mailto:toefftoeff1 at gmx.net>>
> Hello,
> I would like to build and use OGR with GEOS support on Windows XP
> 32 bit
> using
> Visual Basic.NET (.NET framework 2.0 or 3.5).
> GDAL/OGR 1.7.1 and GEOS 2.3.0 compilation seem to work fine (using
> nmake, Visual Studio 2008, only
> warnings, no error messages).
> I used the following GDAL/OGR nmake.opt settings to include GEOMS
> support:
> # Uncomment for GEOS support
> GEOS_DIR=D:\svn\code\Tools\geos-3.2.0
> -DHAVE_GEOS
> GEOS_LIB = $(GEOS_DIR)/build/msvc90/Release/geos_c_i.lib
> But using GEOMS in a sample .NET project always results in an
> exception
> "GEOS support not enabled".
> Sample code:
> Ogr.RegisterAll()
> Dim g1 As Geometry = Geometry.CreateFromWkt("POLYGON((0 0,
> 10 10, 10 0, 0 0))")
> Dim g2 As Geometry = Geometry.CreateFromWkt("POLYGON((-90
> -90, -90 90, 190 -90, -90 -90))")
> Dim result As Boolean = g2.Contains(g1)
> I copied all GDAL/OGR wrapper libraries and geos_c.dll to the
> appropriate places.
> Any suggestions?
> Thanks a lot...
> Christoph
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100308/f2726464/attachment.html
