[gdal-dev] questions about S-57
Frank Warmerdam
warmerdam at pobox.com
Mon Mar 15 07:09:10 EDT 2010
Randy wrote:
> Hi Frank and list,
> I have several questions which are not relevant to GDAL/OGR itself, but
> S-57 format.
> Wish any hint, thanks!
> NO.1
> I’d like to know whether PRIM is as same as NAME_RCNM? If not, what’s
> the difference between the two?
Randy,
Reviewing a WRECKS feature I see they are not, I have:
PRIM (Integer) = 1
NAME_RCNM (IntegerList) = (1:110)
NAME_RCID (IntegerList) = (1:498)
So, RCNM is 110 (isolated node) and PRIM is 1 (point feature). From
the include file:
/* RCNM values. */
#define RCNM_FE 100 /* Feature record */
#define RCNM_VI 110 /* Isolated Node */
#define RCNM_VC 120 /* Connected Node */
#define RCNM_VE 130 /* Edge */
#define RCNM_VF 140 /* Face */
/* FRID PRIM values. */
#define PRIM_P 1 /* point feature */
#define PRIM_L 2 /* line feature */
#define PRIM_A 3 /* area feature */
#define PRIM_N 4 /* non-spatial feature */
> NO.2
> I got some info via ogrinfo from a s-57 file(*.000). In a caution area
> object(CTNARE),some fields are as follows:
> PRIM=3---------------------------------------------------which means the
> object’s geometry is a face, right?
Yes, it means it is an area feature.
> NAME_RCNM=130-----------------------------------which means the vector
> record’s type is edge, I guess. But the next three fields should exist
> with a face vector record(5.1.3.3 chapter in S-57 Editon3.1 seems give
> this hint, but I’m not sure it’s true.)
> ORNT=2:2,2
> USAG=2:1,1
> MASK=2:255,255
Was there a question in here?
> And another two questions:
> NO.1
> The field value in spatial records such as “NAME_RCID=2:25,413” has a
> prefix “2:”, does it mean the field belong to spatial record not feature
> record?
The fields NAME_RCID and and NAME_RCNM are list fields, so the first
value is the report is the count of items in the list followed by a
colon, and then the list of values separated by commas. It is just
a particular reporting format of the ogrinfo program.
> NO.2
> And why one is 25,and another is 413?Does it mean 25 is the ID in
> spatial record and 413 is the ID in the whole record?
It presumably means there are two edge objects one with
RCID=25 and one with RCID=413.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
