[gdal-dev] gdalinfo error 4
Thu Mar 18 12:57:48 EDT 2010
Chris,
If possible, it would be helpful if you could make the file
available for folks to review.  The GRIB driver has a variety
of limitations and it can be confused by some GRIB products.
Best regards,
On Thu, Mar 18, 2010 at 10:31 AM, Chris Haste <CHaste at airdata.co.uk> wrote:
> Hi Frank and list,
> I am very new to gdal and seem to have a problem that I wasn’t expecting.
> I have a GRIB1 file that represents wind and temperature data. It was issued
> by the UK Met Office and contains GRIB bulletins wrapped in the WMO bulletin
> distribution envelope.
> When I run gdalinfo (1.7.1) against this file I get the following error:
> ERROR:  Couldn’t find ‘GRIB’ or ‘TDLP’
> There were 4 trailing bytes in the file.
> ERROR 4: SADISGrib1-0000-T+6.grb is a grib file, but no raster dataset was
> successfully identified.
> Gdalinfo failed – unable to open ‘SADISGrib1-0000-T+6.grb’.
> Can anyone throw some light on this please?
> I can attach the file if needed.
> Thanks in advance,
> Chris
> *** This communication has been sent from World Fuel Services
> Corporation or its subsidiaries or its affiliates for the intended recipient
> only and may contain proprietary, confidential or privileged information.
> If you are not the intended recipient, any review, disclosure, copying,
> use, or distribution of the information included in this communication
> and any attachments is strictly prohibited. If you have received this
> communication in error, please notify us immediately by replying to this
> communication and delete the communication, including any
> attachments, from your computer. Electronic communications sent to or
> from World Fuel Services Corporation or its subsidiaries or its affiliates
> may be monitored for quality assurance and compliance purposes.***
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
