[gdal-dev] writing DWG/DXF
Frank Warmerdam
warmerdam at pobox.com
Thu Mar 18 13:15:53 EDT 2010
On Thu, Mar 18, 2010 at 6:47 AM, Frederik Ramm <frederik at remote.org> wrote:
> Hi,
> Andreas Neumann wrote:
>> yes - it is a read/write driver.
> I have meanwhile checked out and tried it successfully. My use case is
> taking shape files with geodata (road networks, railway, land use etc) and
> converting them to DXF for a client of mine. I created a set of DXF files
> from my shapes and checked them in QCAD.
> Sadly I only get geometries, no extra attributes ("DXF layer does not
> support arbitrary field creation."). I can work around this by creating one
> shape file for every type of feature, but I'll never get something like
> street names that way.
Frederik,
It is not immediately obvious to me how to attach general purpose
attributes to DXF entities in a way that will be useful so I have not
yet attempted this. With some guidance something could likely be
done.
>> There will be further work on this provider. If you (or someone else)
>> would have some money for improvements it would help as well.
> Is not being able to convert something like a street name a fundamental
> problem of DXF, or is this something that could be implemented for a client
> willing to part with some money?
I think there is ambiguity or at least several different ways
of associating what we think of as attribute data. So something
can be done with money/time but I'm concerned it won't be
as generally useful as it could be. It would also take some
investigation to come up with the best method.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
