[gdal-dev] writing DWG/DXF
Reinaldo Escada Chohfi
reinaldo at geodesign.com.br
Thu Mar 18 13:41:38 EDT 2010
Features can have attributes in DXF as BLOCKS. See the attached file for
an example of a POINT feature with attributes asDXF. The same can be done
for line, polyline, polygon, etc.
Regards,
Reinaldo
> On Thu, Mar 18, 2010 at 6:47 AM, Frederik Ramm <frederik at remote.org>
> wrote:
>> Hi,
>> Andreas Neumann wrote:
>>> yes - it is a read/write driver.
>> I have meanwhile checked out and tried it successfully. My use case is
>> taking shape files with geodata (road networks, railway, land use etc)
>> and
>> converting them to DXF for a client of mine. I created a set of DXF
>> files
>> from my shapes and checked them in QCAD.
>> Sadly I only get geometries, no extra attributes ("DXF layer does not
>> support arbitrary field creation."). I can work around this by creating
>> one
>> shape file for every type of feature, but I'll never get something like
>> street names that way.
> Frederik,
> It is not immediately obvious to me how to attach general purpose
> attributes to DXF entities in a way that will be useful so I have not
> yet attempted this. With some guidance something could likely be
> done.
>>> There will be further work on this provider. If you (or someone else)
>>> would have some money for improvements it would help as well.
>> Is not being able to convert something like a street name a fundamental
>> problem of DXF, or is this something that could be implemented for a
>> client
>> willing to part with some money?
> I think there is ambiguity or at least several different ways
> of associating what we think of as attribute data. So something
> can be done with money/time but I'm concerned it won't be
> as generally useful as it could be. It would also take some
> investigation to come up with the best method.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Diretor Geral
GeoDesign Internacional - www.geodesign.com.br
E-mail: reinaldo at geodesign.com.br
Tel./Fax: +55-12-3153-5115
Skype: rechohfi
Inteligência e Tecnologia GeoEspacial de Ponta
Informação confidencial. Não retransmitir sem autorização.
Copyright (c) 2009 GeoDesign Internacional
Todos os direitos reservados.
0
SECTION
2
HEADER
9
$ACADVER
1
AC1009
9
$EXTMIN
10
-45.861725
20
-23.207114
30
0.0
9
$EXTMAX
10
-45.861725
20
-23.207114
30
0.0
9
$LIMMIN
10
0.0
20
0.0
9
$LIMMAX
10
12.0
20
9.0
9
$ORTHOMODE
70
0
9
$REGENMODE
70
1
9
$FILLMODE
70
1
9
$QTEXTMODE
70
0
9
$MIRRTEXT
70
0
9
$DRAGMODE
70
2
9
$LTSCALE
40
1.0
9
$OSMODE
70
77
9
$ATTMODE
70
1
9
$TEXTSIZE
40
0.2
9
$TRACEWID
40
0.05
9
$TEXTSTYLE
7
STANDARD
9
$CLAYER
8
FOTOS_GEORREFERENCIADAS
9
$CELTYPE
6
BYLAYER
9
$CECOLOR
62
7
9
$DIMSCALE
40
1.0
9
$DIMASZ
40
0.18
9
$DIMEXO
40
0.0625
9
$DIMDLI
40
0.38
9
$DIMRND
40
0.0
9
$DIMDLE
40
0.0
9
$DIMEXE
40
0.18
9
$DIMTP
40
0.0
9
$DIMTM
40
0.0
9
$DIMTXT
40
0.18
9
$DIMCEN
40
0.09
9
$DIMTSZ
40
0.0
9
$DIMTOL
70
0
9
$DIMLIM
70
0
9
$DIMTIH
70
1
9
$DIMTOH
70
1
9
$DIMSE1
70
0
9
$DIMSE2
70
0
9
$DIMTAD
70
0
9
$DIMZIN
70
0
9
$DIMBLK
1
9
$DIMASO
70
1
9
$DIMSHO
70
1
9
$DIMPOST
1
9
$DIMAPOST
1
9
$DIMALT
70
0
9
$DIMALTD
70
2
9
$DIMALTF
40
25.399999999999999
9
$DIMLFAC
40
1.0
9
$DIMTOFL
70
0
9
$DIMTVP
40
0.0
9
$DIMTIX
70
0
9
$DIMSOXD
70
0
9
$DIMSAH
70
0
9
$DIMBLK1
1
9
$DIMBLK2
1
9
$DIMSTYLE
2
STANDARD
9
$DIMCLRD
70
0
9
$DIMCLRE
70
0
9
$DIMCLRT
70
0
9
$DIMTFAC
40
1.0
9
$DIMGAP
40
0.09
9
$LUNITS
70
2
9
$LUPREC
70
4
9
$SKETCHINC
40
0.1
9
$FILLETRAD
40
0.0
9
$AUNITS
70
0
9
$AUPREC
70
0
9
$MENU
1
9
$ELEVATION
40
0.0
9
$PELEVATION
40
0.0
9
$THICKNESS
40
0.0
9
$LIMCHECK
70
0
9
$BLIPMODE
70
0
9
$CHAMFERA
40
0.0
9
$CHAMFERB
40
0.0
9
$SKPOLY
70
0
9
$TDCREATE
40
2455010.5500146411
9
$TDUPDATE
40
2455019.7225251272
9
$TDINDWG
40
0.0149699884
9
$TDUSRTIMER
40
0.0149698032
9
$USRTIMER
70
1
9
$ANGBASE
50
0.0
9
$ANGDIR
70
0
9
$PDMODE
70
34
9
$PDSIZE
40
-1.5
9
$PLINEWID
40
0.0
9
$COORDS
70
1
9
$SPLFRAME
70
0
9
$SPLINETYPE
70
6
9
$SPLINESEGS
70
8
9
$ATTDIA
70
0
9
$ATTREQ
70
1
9
$HANDLING
70
1
9
$HANDSEED
5
116
9
$SURFTAB1
70
6
9
$SURFTAB2
70
6
9
$SURFTYPE
70
6
9
$SURFU
70
6
9
$SURFV
70
6
9
$UCSNAME
2
9
$UCSORG
10
0.0
20
0.0
30
0.0
9
$UCSXDIR
10
1.0
20
0.0
30
0.0
9
$UCSYDIR
10
0.0
20
1.0
30
0.0
9
$PUCSNAME
2
9
$PUCSORG
10
0.0
20
0.0
30
0.0
9
$PUCSXDIR
10
1.0
20
0.0
30
0.0
9
$PUCSYDIR
10
0.0
20
1.0
30
0.0
9
$USERI1
70
0
9
$USERI2
70
0
9
$USERI3
70
0
9
$USERI4
70
0
9
$USERI5
70
0
9
$USERR1
40
0.0
9
$USERR2
40
0.0
9
$USERR3
40
0.0
9
$USERR4
40
0.0
9
$USERR5
40
0.0
9
$WORLDVIEW
70
1
9
$SHADEDGE
70
3
9
$SHADEDIF
70
70
9
$TILEMODE
70
1
9
$MAXACTVP
70
64
9
$PLIMCHECK
70
0
9
$PEXTMIN
10
0.0
20
0.0
30
0.0
9
$PEXTMAX
10
0.0
20
0.0
30
0.0
9
$PLIMMIN
10
0.0
20
0.0
9
$PLIMMAX
10
12.0
20
9.0
9
$UNITMODE
70
0
9
$VISRETAIN
70
1
9
$PLINEGEN
70
0
9
$PSLTSCALE
70
1
0
ENDSEC
0
SECTION
2
TABLES
0
TABLE
2
VPORT
70
3
0
VPORT
2
*ACTIVE
70
0
10
0.0
20
0.0
11
1.0
21
1.0
12
-45.861725
22
-23.207114
13
0.0
23
0.0
14
0.5
24
0.5
15
0.5
25
0.5
16
0.0
26
0.0
36
1.0
17
0.0
27
0.0
37
0.0
40
3.00
41
1.50
42
50.0
43
0.0
44
0.0
50
0.0
51
0.0
71
0
72
1000
73
1
74
3
75
0
76
0
77
0
78
0
0
ENDTAB
0
TABLE
2
LTYPE
70
1
0
LTYPE
2
CONTINUOUS
70
0
3
Solid line
72
65
73
0
40
0.0
0
ENDTAB
0
TABLE
2
LAYER
70
2
0
LAYER
2
0
70
0
62
7
6
CONTINUOUS
0
LAYER
2
70
0
62
7
6
CONTINUOUS
0
ENDTAB
0
TABLE
2
STYLE
70
1
0
STYLE
2
STANDARD
70
0
40
0.0
41
1.0
50
0.0
71
0
42
0.2
3
txt
4
0
ENDTAB
0
TABLE
2
VIEW
70
0
0
ENDTAB
0
TABLE
2
UCS
70
0
0
ENDTAB
0
TABLE
2
APPID
70
1
0
APPID
2
ACAD
70
0
0
ENDTAB
0
TABLE
2
DIMSTYLE
70
1
0
DIMSTYLE
2
STANDARD
70
0
3
4
5
6
7
40
1.0
41
0.18
42
0.0625
43
0.38
44
0.18
45
0.0
46
0.0
47
0.0
48
0.0
140
0.18
141
0.09
142
0.0
143
25.399999999999999
144
1.0
145
0.0
146
1.0
147
0.09
71
0
72
0
73
1
74
1
75
0
76
0
77
0
78
0
170
0
171
2
172
0
173
0
174
0
175
0
176
0
177
0
178
0
0
ENDTAB
0
ENDSEC
0
SECTION
2
BLOCKS
0
BLOCK
8
0
2
$MODEL_SPACE
70
0
10
0.0
20
0.0
30
0.0
3
$MODEL_SPACE
1
0
ENDBLK
5
F8
8
0
0
BLOCK
67
1
8
0
2
$PAPER_SPACE
70
0
10
0.0
20
0.0
30
0.0
3
$PAPER_SPACE
1
0
ENDBLK
5
F4
67
1
8
0
0
BLOCK
8
0
2
BLK1
70
2
10
0.0
20
0.0
30
0.0
3
BLK1
1
0
POINT
5
200
8
0
62
7
10
-45.861725
20
-23.207114
30
0.0
0
ATTDEF
5
201
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
NOME
70
1
0
ATTDEF
5
202
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
DIRETORIO
70
1
0
ATTDEF
5
203
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
DATUM
70
1
0
ATTDEF
5
204
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
PROJECAO
70
1
0
ATTDEF
5
205
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
LATITUDE
70
1
0
ATTDEF
5
206
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
LONGITUDE
70
1
0
ATTDEF
5
207
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
ALTITUDE_M
70
1
0
ATTDEF
5
208
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
ORI_MAGNET
70
1
0
ATTDEF
5
209
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
ORI_VERDAD
70
1
0
ATTDEF
5
210
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
DECLINACAO
70
1
0
ATTDEF
5
211
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
LAT_DEST
70
1
0
ATTDEF
5
212
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
LON_DEST
70
1
0
ATTDEF
5
213
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
ORI_MAG_DEST
70
1
0
ATTDEF
5
214
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
ORI_VER_DEST
70
1
0
ATTDEF
5
215
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
DECL_DEST
70
1
0
ATTDEF
5
216
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
DIST_DEST
70
1
0
ATTDEF
5
217
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
DATA
70
1
0
ATTDEF
5
218
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
HORARIO
70
1
0
ATTDEF
5
219
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
SATELITES
70
1
0
ATTDEF
5
220
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
DATA_SAT
70
1
0
ATTDEF
5
221
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
HORA_UTC
70
1
0
ATTDEF
5
222
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
MEASURE
70
1
0
ATTDEF
5
223
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
DOP
70
1
0
ATTDEF
5
224
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
FABRICANTE
70
1
0
ATTDEF
5
225
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
MODELO
70
1
0
ATTDEF
5
226
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
EXP_TIME
70
1
0
ATTDEF
5
227
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
EXP_MODE
70
1
0
ATTDEF
5
228
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
FNUMBER
70
1
0
ATTDEF
5
229
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
FLASH
70
1
0
ATTDEF
5
230
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
WHITE_BAL
70
1
0
ATTDEF
5
231
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
BRIGHTNESS
70
1
0
ATTDEF
5
232
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
ISO
70
1
0
ATTDEF
5
233
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
METER_MODE
70
1
0
ATTDEF
5
234
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
SHARPNESS
70
1
0
ATTDEF
5
235
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
WIDTH
70
1
0
ATTDEF
5
236
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
HEIGHT
70
1
0
ATTDEF
5
237
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
CRS_REPROJ
70
1
0
ATTDEF
5
238
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
COORD_X
70
1
0
ATTDEF
5
239
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
COORD_Y
70
1
0
ATTDEF
5
240
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
ATRIB_01
70
1
0
ATTDEF
5
241
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
ATRIB_02
70
1
0
ATTDEF
5
242
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
ATRIB_03
70
1
0
ATTDEF
5
243
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
ATRIB_04
70
1
0
ATTDEF
5
244
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
ATRIB_05
70
1
0
ATTDEF
5
245
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
ATRIB_06
70
1
0
ATTDEF
5
246
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
ATRIB_07
70
1
0
ATTDEF
5
247
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
ATRIB_08
70
1
0
ATTDEF
5
248
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
ATRIB_09
70
1
0
ATTDEF
5
249
8
0
10
0.0
20
0.0
30
0.0
40
0.2
1
3
2
ATRIB_10
70
1
0
ENDBLK
5
250
8
0
0
BLOCK
8
0
2
A$C1AB21049
70
0
10
0.0
20
0.0
30
0.0
3
A$C1AB21049
1
0
INSERT
5
251
8
66
1
2
BLK1
10
-45.861725
20
-23.207114
30
0.0
0
ATTRIB
5
252
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
2
NOME
70
1
0
ATTRIB
5
253
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
C:\fotos\all_formats\
2
DIRETORIO
70
1
0
ATTRIB
5
254
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
WGS-84
2
DATUM
70
1
0
ATTRIB
5
255
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
LAT/LON
2
PROJEÇÃO
70
1
0
ATTRIB
5
256
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
23 graus 12 min 25.61 seg S
2
LATITUDE
70
1
0
ATTRIB
5
257
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
45 graus 51 min 42.21 seg O
2
LONGITUDE
70
1
0
ATTRIB
5
258
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
604
2
ALTITUDE_M
70
1
0
ATTRIB
5
259
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
224.300
2
ORI_MAGNET
70
1
0
ATTRIB
5
260
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
203.641
2
ORI_VERDAD
70
1
0
ATTRIB
5
261
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
-20.659
2
DECLINACAO
70
1
0
ATTRIB
5
262
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
N/D
2
INCL_HOR
70
1
0
ATTRIB
5
263
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
N/D
2
INCL_VER
70
1
0
ATTRIB
5
264
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
N/D
2
LAT_DEST
70
1
0
ATTRIB
5
265
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
N/D
2
LON_DEST
70
1
0
ATTRIB
5
266
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
20.659
2
ORI_MAG_DEST
70
1
0
ATTRIB
5
267
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
0.00
2
ORI_VER_DEST
70
1
0
ATTRIB
5
268
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
-20.659
2
DECL_DEST
70
1
0
ATTRIB
5
269
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
0.00
2
DIST_DEST
70
1
0
ATTRIB
5
270
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
2009:03:11
2
DATA
70
1
0
ATTRIB
5
271
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
14:50:33
2
HORARIO
70
1
0
ATTRIB
5
272
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
02,15,27,17,26,04,12,09,28,05
2
SATELITES
70
1
0
ATTRIB
5
273
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
2009:03:11
2
DATA_SAT
70
1
0
ATTRIB
5
274
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
16:52:26
2
HORA_UTC
70
1
0
ATTRIB
5
275
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
3D Diff
2
MEASURE
70
1
0
ATTRIB
5
276
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
1.50
2
DOP
70
1
0
ATTRIB
5
277
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
RICOH
2
FABRICANTE
70
1
0
ATTRIB
5
278
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
Caplio 500SE
2
MODELO
70
1
0
ATTRIB
5
279
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
0.005291
2
EXP_TIME
70
1
0
ATTRIB
5
280
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
Auto exp.
2
EXP_MODE
70
1
0
ATTRIB
5
281
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
4.30
2
FNUMBER
70
1
0
ATTRIB
5
282
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
Off
2
FLASH
70
1
0
ATTRIB
5
283
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
Auto
2
WHITE_BAL
70
1
0
ATTRIB
5
284
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
5.50
2
BRIGHTNESS
70
1
0
ATTRIB
5
285
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
64
2
ISO
70
1
0
ATTRIB
5
286
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
Pattern
2
METER_MODE
70
1
0
ATTRIB
5
287
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
Normal
2
SHARPNESS
70
1
0
ATTRIB
5
288
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
1280
2
WIDTH
70
1
0
ATTRIB
5
289
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
960
2
HEIGHT
70
1
0
ATTRIB
5
290
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
N/D
2
CRS_REPROJ
70
1
0
ATTRIB
5
291
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
N/D
2
COORD_X
70
1
0
ATTRIB
5
292
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
N/D
2
COORD_Y
70
1
0
ATTRIB
5
293
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
N/D
2
ATRIB_01
70
1
0
ATTRIB
5
294
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
N/D
2
ATRIB_02
70
1
0
ATTRIB
5
295
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
N/D
2
ATRIB_03
70
1
0
ATTRIB
5
296
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
N/D
2
ATRIB_04
70
1
0
ATTRIB
5
297
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
N/D
2
ATRIB_05
70
1
0
ATTRIB
5
298
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
N/D
2
ATRIB_06
70
1
0
ATTRIB
5
299
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
N/D
2
ATRIB_07
70
1
0
ATTRIB
5
300
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
N/D
2
ATRIB_08
70
1
0
ATTRIB
5
301
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
N/D
2
ATRIB_09
70
1
0
ATTRIB
5
302
8
0
10
1.334568664741588
20
0.9815886637563231
30
0.0
40
0.2
1
N/D
2
ATRIB_10
70
1
0
SEQEND
5
303
8
62
7
0
ENDBLK
5
304
8
0
0
ENDSEC
0
SECTION
2
ENTITIES
0
INSERT
5
305
8
66
1
2
BLK1
10
0.0
20
0.0
30
0.0
0
ATTRIB
5
306
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
2
NOME
70
1
0
ATTRIB
5
307
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
2
DIRETORIO
70
1
0
ATTRIB
5
308
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
WGS-84
2
DATUM
70
1
0
ATTRIB
5
309
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
LAT/LON
2
PROJECAO
70
1
0
ATTRIB
5
310
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
2
LATITUDE
70
1
0
ATTRIB
5
311
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
2
LONGITUDE
70
1
0
ATTRIB
5
312
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
604
2
ALTITUDE_M
70
1
0
ATTRIB
5
313
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
224.300
2
ORI_MAGNET
70
1
0
ATTRIB
5
314
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
203.641
2
ORI_VERDAD
70
1
0
ATTRIB
5
315
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
-20.659
2
DECLINACAO
70
1
0
ATTRIB
5
316
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
N/D
2
INCL_HOR
70
1
0
ATTRIB
5
317
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
N/D
2
INCL_VER
70
1
0
ATTRIB
5
318
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
N/D
2
LAT_DEST
70
1
0
ATTRIB
5
319
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
N/D
2
LON_DEST
70
1
0
ATTRIB
5
320
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
20.659
2
ORI_MAG_DEST
70
1
0
ATTRIB
5
321
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
0.00
2
ORI_VER_DEST
70
1
0
ATTRIB
5
322
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
-20.659
2
DECL_DEST
70
1
0
ATTRIB
5
323
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
0.00
2
DIST_DEST
70
1
0
ATTRIB
5
324
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
2009:03:11
2
DATA
70
1
0
ATTRIB
5
325
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
14:50:33
2
HORARIO
70
1
0
ATTRIB
5
326
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
2
SATELITES
70
1
0
ATTRIB
5
327
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
2009:03:11
2
DATA_SAT
70
1
0
ATTRIB
5
328
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
16:52:26
2
HORA_UTC
70
1
0
ATTRIB
5
329
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
3D Diff
2
MEASURE
70
1
0
ATTRIB
5
330
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
1.50
2
DOP
70
1
0
ATTRIB
5
331
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
RICOH
2
FABRICANTE
70
1
0
ATTRIB
5
332
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
Caplio 500SE
2
MODELO
70
1
0
ATTRIB
5
333
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
0.005291
2
EXP_TIME
70
1
0
ATTRIB
5
334
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
Auto exp.
2
EXP_MODE
70
1
0
ATTRIB
5
335
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
4.30
2
FNUMBER
70
1
0
ATTRIB
5
336
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
Off
2
FLASH
70
1
0
ATTRIB
5
337
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
Auto
2
WHITE_BAL
70
1
0
ATTRIB
5
338
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
5.50
2
BRIGHTNESS
70
1
0
ATTRIB
5
339
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
64
2
ISO
70
1
0
ATTRIB
5
340
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
Pattern
2
METER_MODE
70
1
0
ATTRIB
5
341
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
Normal
2
SHARPNESS
70
1
0
ATTRIB
5
342
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
1280
2
WIDTH
70
1
0
ATTRIB
5
343
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
960
2
HEIGHT
70
1
0
ATTRIB
5
344
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
N/D
2
CRS_REPROJ
70
1
0
ATTRIB
5
345
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
N/D
2
COORD_X
70
1
0
ATTRIB
5
346
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
N/D
2
COORD_Y
70
1
0
ATTRIB
5
347
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
N/D
2
ATRIB_01
70
1
0
ATTRIB
5
348
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
N/D
2
ATRIB_02
70
1
0
ATTRIB
5
349
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
N/D
2
ATRIB_03
70
1
0
ATTRIB
5
350
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
N/D
2
ATRIB_04
70
1
0
ATTRIB
5
351
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
N/D
2
ATRIB_05
70
1
0
ATTRIB
5
352
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
N/D
2
ATRIB_06
70
1
0
ATTRIB
5
353
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
N/D
2
ATRIB_07
70
1
0
ATTRIB
5
354
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
N/D
2
ATRIB_08
70
1
0
ATTRIB
5
355
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
N/D
2
ATRIB_09
70
1
0
ATTRIB
5
356
8
0
10
-45.861725
20
-23.207114
30
0.0
40
0.2
1
N/D
2
ATRIB_10
70
1
0
SEQEND
5
357
8
62
7
0
ENDSEC
0
EOF
