[gdal-dev] Python 32 crash on Windows Server 2008 64 bit with Gdal
Silvia Rolla
silvietta.rolla at gmail.com
Mon Mar 29 10:21:44 EDT 2010
HI all,
I am using gdal from python on my workstation (Windows Vista Ultimate 32
bit) with the following snip of code:
from osgeo import gdal
from osgeo import gdalconst
dataset = gdal.Open("D:\data\\20100325_12_00.grb", gdal.GA_ReadOnly)
metadata=dataset.GetRasterBand(1)
metadata.ReadRaster(220, 148, 1, 1, 1, 1, metadata.DataType)
When i port the same code on the production server,
python crashes on the metadata.ReadRaster(...) instruction.
A message box show up with the following information:
Problem signature:
Problem Event Name: APPCRASH
Application Name: python.exe
Application Version: 0.0.0.0
Application Timestamp: 49e4f549
Fault Module Name: ntdll.dll
Fault Module Version: 6.1.7600.16385
Fault Module Timestamp: 4a5bdb3b
Exception Code: c0000005
Exception Offset: 00037075
OS Version: 6.1.7600.2.0.0.272.7
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Configuration of the production server is:
Operating System: Windows Server 2008 R2 64 Bit
Python Win32 2.6.2
Gdal Win32 1.6
numpy-1.3.0-win32-superpack-python2.6
Looks like many people had problem running gdal with python 32bit on 64 bit
machine.
Could you please help on this?
Thanks in advance
Silvia
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100329/b1c83ad7/attachment.html
