[gdal-dev] Re: rgdal source code
Lucena, Ivan ivan.lucena at pmldnet.com
Wed Mar 31 16:34:04 EDT 2010
Hi Jason/Roger,
I started that thread based on the wrong impression that I would be the one in change of helping
some folks to get up and running with R and the RGDAL library. I thought that I would need to
compile RGDAL against the GDAL just like I usually do for GDAL/Python and GDAL/Java in Windows and
Linux. Turns out that that is not the case. Not anymore. Somebody did a great job updating to GDAL
1.7.1, so now it is pretty simple and convenient to install RGDAL direct from the R GUI from the
closest mirror site. That is great. Well, at least for Win32. So, I rest my thread. I mean, I don't
need the "rgdal source code" anymore.
My best regards,
Ivan
Jason Roberts wrote:
> Roger,
> Thanks for the info. I have never built GDAL with MSYS before, only with the
> various Microsoft compilers. The GDAL team provides pre-configured build
> environments for those compilers that produce the library with names
> gdal16.dll, gdal17.dll, etc. I assumed that it would work that way for other
> compilers as well. In any case, I have some interest in the architecture of
> rgdal and may follow up with you about it in the future.
> My colleagues and I would like to see rgdal on 64-bit Windows but
> unfortunately we cannot contribute any time to porting it. However, we do
> have at least one 64-bit server and if you are blocked on access to a
> suitable machine, I might be able to arrange for you to use ours via Windows
> Remote Desktop. The machine is currently running the 32-bit OS so our IT
> guys would have to reinstall it. This would likely take some time to
> schedule so I don't know that it could be done soon enough for you to make
> the R 2.11 date. But if you are interested, contact me offline and I'll see
> what can be done.
> Best,
> Jason
> -----Original Message-----
> From: Roger Bivand [mailto:Roger.Bivand at nhh.no]
> Sent: Friday, March 26, 2010 2:51 PM
> To: Jason Roberts
> Cc: gdal-dev at lists.osgeo.org
> Subject: RE: [gdal-dev] Re: rgdal source code
> On Fri, 26 Mar 2010, Jason Roberts wrote:
>> Roger,
>> Pardon me for interrupting with a question I've had for a while but not
>> asked you.
>> On Windows at least, it appears that rgdal renames the GDAL shared library
>> (e.g. gdal16.dll) to an rgdal-specific name (e.g. libgdal-1.dll). On
>> windows, this has the advantage of avoiding DLL name collisions, allowing
>> rgdal to coexist with other libraries that also load GDAL using its
>> traditional name (e.g. gdal16.dll). Is that why rgdal renamed the shared
>> library? Or was it done for another reason?
> Jason,
> No, it is the name it gets when built under MSYS by default, nothing
> cleverer than that, I'm afraid!
> This is a different question entirely, but a heads-up might be worthwhile.
> When R 2.11 arrives in three weeks time, there will be a 64-bit Windows
> version. Because of the external dependencies on expat, proj4, and GDAL,
> rgdal is one of only a very small group of CRAN packages that is not
> available as a 64-bit Windows binary. It would be very useful if 64-bit
> Windows users got together and figured out how to make a bundle of 64-bit
> DLLs that could automate the CRAN Windows build of rgdal also for 64-bit
> Windows. R is built with MinGW, so in the MSYS family. I have no access to
> such a Windows platform, but have some advice from Brian Ripley, and one
> interested helper. The more the merrier!
> Roger
>> Thanks,
>> Jason
>> From: gdal-dev-bounces at lists.osgeo.org
>> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Roger Bivand
>> Sent: Friday, March 26, 2010 11:09 AM
>> To: Ivan Lucena
>> Subject: Re: [gdal-dev] Re: rgdal source code
>> On Fri, 26 Mar 2010, Ivan Lucena wrote:
>>> Roger,
>>> Yes, you are right. The source code is on  rgdal_0.6-25.tar.gz, I know,
>> but the instructions to build on Windows are on the rgdal_0.6-25.zip
> package
>> on README.windows, where it says:
>>> The R Windows binary rgdal package is built against an FWTools Windows
>> binary, using VC++.
>>> Notes:
>>> Building rgdal.dll in rgdal/src:
>>> cl /MT /Ox /EHsc /D "WIN32" /c /I E:\rsb\R\R-2.2.1pat\include /I
>> C:\Programfiler\FWTools1.0.0a7\incl
>>> ude *.cpp
>>> link /dll /out:rgdal.dll /def:RGDAL.def gdal-bindings.obj ogr_geom.obj
>> ogr_proj.obj ogrsource.obj E:
>>> \rsb\R\R-2.2.1pat\lib\Rdll.lib
>> /libpath:"C:\Programfiler\FWTools1.0.0a7\lib" gdal_i.lib
>>> So I am trying to change it a little bit in order to build against GDAL
>> 1.7.1 (or trunk).
>>> How does that sounds to you? Good idea?
>> Ivan,
>> No, the README.windows file is of course in the source tarball, in the
>> inst directory (as usual for R packages).
>> If you install the Windows binary, you'll see that it includes GDAL 1.7.1,
>> that is the message reporting the GDAL runtime version shown when the
>> package is loaded. The only reason for doing anything at all is if you
>> need drivers not already provided for your own purposes. Then you might
>> need to review the README.windows file and, for example, build against
>> current FWTools or OSGEO4W distributions. Please do check the drivers
>> first with ogrDrivers() and gdalDrivers() in R after loading the package.
>> Roger
>>> Regards,
>>> Ivan
>>>>  -------Original Message-------
>>>>  From: Roger Bivand <Roger.Bivand at nhh.no>
>>>>  To: gdal-dev at lists.osgeo.org
>>>>  Subject: [gdal-dev] Re: rgdal source code
>>>>  Sent: Mar 26 '10 09:31
>>>>  The root cause of the sourceforge issue is in a message posted
>> 2010-03-25
>>>>  from their admin:
>>>>  "Update on the current CVS outage that is affecting projects whose UNIX
>>>>  names start with the letters  a, e, h, i, m, o, r, s, w, z.
>>>>  The work being done on this server may take up to two days to resolve.
>> We?re
>>>>  working to resolve this with alacrity and assure maximum stability and
>>>>  performance."
>>>>  So access should be back by the end of March.
>>>>  Roger
>>>>  Roger Bivand wrote:
>>>>> On Thu, 25 Mar 2010, Ivan wrote:
>>>>>> Roger,
>>>>>> I in fact did my homework, but I've got a C.
>>>>>> As you can see on my previous message I did find the RGDAL Source
>> Forge
>>>>>> page
>>>>>> where it shows the CVS instructions ===> [1] <===. That would give a
>> B+
>>>>>> at
>>>>>> least, no? If it worked.
>>>>>> cvs -d:pserver:anonymous at rgdal.cvs.sourceforge.net:/cvsroot/rgdal
>> login
>>>>>> Logging in to
>>>>>> :pserver:anonymous at rgdal.cvs.sourceforge.net:2401/cvsroot/rgdal
>>>>>> CVS password:
>>>>>> cvs [login aborted]: connect to
>>>>>> rgdal.cvs.sourceforge.net(216.34.181.108):2401 failed: Connection
>> refused
>>>>>> That was a dead end.
>>>>> Correct. When I tried, anonymous checkout from sourceforge was also
>>>>> blocked - nothing we've done, maybe something sourceforge has done. I
>> have
>>>>> changed the main description to:
>>>>> "WARNING: rgdal is only available for download from CRAN - this
>> repository
>>>>> is only used for development and browsing of source code. NEVER use the
>>>>> very out of date file bundles for download from this site!!! See
>>>>> http://rgdal.sourceforge.net for link."
>>>>> Short of migrating to R-forge (which I have done for another R package,
>>>>> spdep), there isn't much that can be done with sourceforge, I'm afraid
>>>>> (sourceforge isn't my favorite place to be).
>>>>> cc: Tim: Any idea why the anonymous checkout fails? Longer term - is
>>>>> migration to SVN on R-Forge worth considering?
>>>>> Roger
>>>>>> I download some of those zip packages from rgdal.sourceforge.net but
>> they
>>>>>> only have binary that requires FWTools installation.
>>>>>> Another dead end.
>>>>>> But you are right I should have search a little more to find the CRAN
>>>>>> page.
>>>>>> So I am downloading rgdal_0.6-2.5.zip now. Let's see how it goes.
>>>>> That is the current Windows CRAN binary, get rgdal_0.6-25.tar.gz for
>> the
>>>>> source. Install the Windows binary within R - do *not* treat the zip
>>>>> archive as an archive - it is just a frozen binary version of the
>> source
>>>>> for Windows.
>>>>> Roger
>>>>>> Thanks you so very much Roger. Have a nice day.
>>>>>> Ivan
>>>>>> Roger Bivand wrote:
>>>>>>> Please, do your homework!
>>>>>>> Google on "R rgdal" gives:
>>>>>>> http://cran.r-project.org/web/packages/rgdal/index.html
>>>>>>> http://rgdal.sourceforge.net/
>>>>>>> where the latter says: "The R contributed package rgdal is available
>>>>>>> from
>>>>>>> CRAN", that is the first link. On CRAN you will find both the source
>>>>>>> tarball
>>>>>>> and a Windows 32-bit binary including 1.7.1 with standard drivers and
>>>>>>> expat
>>>>>>> for reading KML etc.
>>>>>>> The sourceforge site is used exclusively as a CVS repository for
>>>>>>> developers
>>>>>>> - it hasn't been used for software distribution since about 2004; the
>>>>>>> CRAN
>>>>>>> distribution mechanism is far more robust and "just works".
>>>>>>> Refer to show.file(system.file("README.windows", package="rgdal")) if
>>>>>>> you
>>>>>>> need to build from source for more exotic drivers.
>>>>>>> The relevant mailing list is R-sig-geo,
>>>>>>> https://www.stat.math.ethz.ch/mailman/listinfo/R-SIG-Geo/, and the
>> best
>>>>>>> point of entrance, the R Spatial task view:
>>>>>>> http://cran.r-project.org/web/views/Spatial.html.
>>>>>>> Hope this helps,
>>>>>>> Roger
>>>>>>> Ivan-5 wrote:
>>>>>>>> Hi there,
>>>>>>>> I am trying to get RGDAL to work with GDAL 1.7.1 but I cannot access
>>>>>>>> the
>>>>>>>> source code [1] and the binaries for Windows depend on some old
>> version
>>>>>>>> of
>>>>>>>> gdal_fw.dll. Does anybody have any clue?
>>>>>>>> Regards,
>>>>>>>> Ivan
>>>>>>>> [1] - http://sourceforge.net/scm/?type=cvs&group_id=84716
>>>>>>>> _______________________________________________
>>>>>>>> gdal-dev mailing list
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>>>>> Roger Bivand
>>>>>>> Economic Geography Section
>>>>>>> Department of Economics
>>>>>>> Norwegian School of Economics and Business Administration
>>>>>>> Helleveien 30
>>>>>>> N-5045 Bergen, Norway
>>>>> Roger Bivand
>>>>> Economic Geography Section, Department of Economics, Norwegian School
>> of
>>>>> Economics and Business Administration, Helleveien 30, N-5045 Bergen,
>>>>> Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
>>>>> e-mail: Roger.Bivand at nhh.no
>>>>  Roger Bivand
>>>>  Helleveien 30
>>>>  View this message in context:
>> http://n2.nabble.com/gdal-dev-rgdal-source-code-tp4799954p4804208.html
>>>>  Sent from the GDAL - Dev mailing list archive at Nabble.com.
