[gdal-dev] how to submit modified drivers for GDAL
Shawn GONG SGONG at mdacorporation.com
Sun May 2 17:07:33 EDT 2010
Frank, Ivan and Kyle,
Thank you for your reply. When you advise me to file a ticket, do you mean "submit a bug report" at this site http://trac.osgeo.org/gdal/?
This is my first time doing this.
I can attach sea surface temperature (SST) netCDF for testing, but not RSAT2 or TSX dataset.
Thanks,
Shawn
-----Original Message-----
From: gdal-dev-bounces at lists.osgeo.org on behalf of Shawn GONG
Sent: Thu 4/29/2010 6:52 PM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] how to submit  modified drivers for GDAL
Hi list,
My colleague, Adam Klein, and I have made changes to the following drivers:
netCDF: corrects for longitudes >180 deg (western hemisphere)
RSAT2: able to ingest NITF complex products
TSX: utilizes all GCPs instead of the default of 5 (4 corners + 1 centre)
Please advise how to submit the changes.
BTW, has ScanSAR mode been added for TerraSAR?
Thanks,
Shawn
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100502/e5d4cc84/attachment.html
