[gdal-dev] how to submit modified drivers for GDAL
Kyle Shannon
ksshannon at gmail.com
Sun May 2 22:37:46 EDT 2010
Correct. Submit the report and document what the change is, attach the patch
and the test data. Thanks.
Kyle Shannon
Physical Science Technician
RMRS Fire Sciences Lab
Fire, Fuels & Smoke - RWU 4405
5775 Highway 10 W.
Missoula, MT 59808
(406)829-6954
kshannon at fs.fed.us
On Sun, May 2, 2010 at 3:07 PM, Shawn GONG <SGONG at mdacorporation.com> wrote:
> Frank, Ivan and Kyle,
> Thank you for your reply. When you advise me to file a ticket, do you mean
> "submit a bug report" at this site http://trac.osgeo.org/gdal/?
> This is my first time doing this.
> I can attach sea surface temperature (SST) netCDF for testing, but not
> RSAT2 or TSX dataset.
> Thanks,
> Shawn
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org on behalf of Shawn GONG
> Sent: Thu 4/29/2010 6:52 PM
> To: gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] how to submit modified drivers for GDAL
> Hi list,
> My colleague, Adam Klein, and I have made changes to the following drivers:
> netCDF: corrects for longitudes >180 deg (western hemisphere)
> RSAT2: able to ingest NITF complex products
> TSX: utilizes all GCPs instead of the default of 5 (4 corners + 1 centre)
> Please advise how to submit the changes.
> BTW, has ScanSAR mode been added for TerraSAR?
> Thanks,
> Shawn
> gdal-dev mailing list
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100502/f0a1d85d/attachment.html
