[gdal-dev] will r.in.gdal use GDALRasterAttributeTable elements?
Neil Best nbest at ci.uchicago.edu
Tue May 4 06:39:08 EDT 2010
[cross-posted on grass-user]
I have a data set in IMG format that has a GDALRasterAttributeTable element
which contains class name metadata that would be perfect for category names,
but I don't see a way to take advantage of it right away.  First of all
there are problems with the file's georeferencing such that its extents are
invalid for geographic coordinates, so I had to gdal_translate it to a VRT,
which caused the GDALRasterAttributeTable to disappear from gdalinfo's
output.  Before I work on finding some other work-around any more than I
already have (to no avail) I would like to know if r.in.gdal can even take
advantage of this extra metadata in any meaningful way, namely to populate
the category labels.  Thanks.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/will-r-in-gdal-use-GDALRasterAttributeTable-elements-tp5002715p5002715.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
