[gdal-dev] Thin Plate Spline
Jan Hartmann
j.l.h.hartmann at uva.nl
Tue May 4 06:08:10 EDT 2010
Thanks Peter, good points. One further question: even if the
georeferenced map as a whole is distorted due to too few control points,
the control points *themselves* should always be projected to their
exact specified georeferenced location, right? At least that is wthat I
thought was the difference between rubber sheeting algorithms like thin
plate spline and polynomial rectifications, where some kind of error is
distributed between the control points.
Oh, and I would be very much interested to know more of your experiences
with the algorithms to be used for rectifying distorted historical maps.
Regards,
Jan
On 05/04/10 08:16, Peter J Halls wrote:
> Jan,
> the number of points required will depend upon the nature of the
> deformation in the originals. You need sufficient control points to
> ensure that the algorithm can sort things out, so relatively more
> points are required in the deformed areas. However, although I've not
> used the GDAL Thin Plate Spline, with many of these algorithms it is
> necessary to also have an even spread of control points, or new
> distortion can be introduced in the previously undistorted areas.
> I would regard five control points as the minimum and suitable only
> for originals that were completely flat when scanned. Five points
> should be enough (just) to deal with orientation errors on the scanner
> and systematic scanner errors. If the original had been folded, for
> example, even had it been ironed before scanning, additional points
> would be needed either side of the former folds, in order to sort out
> the compression they introduce. The worst case I've ever had to deal
> with was a late 19th century map with no known projection details that
> had been segmented and mounted on linen - with gaps between each
> segment. In that case, I ended up transforming each segment and then
> stitching the segments together - it worked remarkably well.
> Hope that helps,
> best wishes,
> Peter
> Jan Hartmann wrote:
>> Hi,
>> I'm rubber-sheeting old, deformed maps using the thin plate spline
>> option of gdalwarp (-tps). My impression was that the control points
>> would be transformed to exactly their georeferenced locations, but in
>> the georeferenced image the control poimts don't quite align with the
>> gcp-coordinates I specified. I'm only using five points per map, so
>> could this be the problem? If so, how many points do I need to get
>> the control points on their exact location? Or are there other ways
>> to achieve this?
>> Jan
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
