[gdal-dev] Re: srs definition for wgs84
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Thu May 13 09:40:00 EDT 2010
-lco must be repeated and typos are no good.  Try
ogr2ogr -f OCI OCI:mdsys/mediation at 10.0.80.31:1521/attmsd
parceldata.shp -skipfailures -lco SRID=4326 -lco DIM=2 -lco GEOMETRY_NAME=GEOM
-nln Parcel1
I do not have Oracle available so I am not 100% sure but it must be close to working command.
-Jukka-
-----Alkuperäinen viesti-----
Lähettäjä: Imran Rajjad [mailto:rajjad at gmail.com]
Lähetetty: to 13.5.2010 15:44
Vastaanottaja: Rahkonen Jukka
Kopio: gdal-dev at lists.osgeo.org
Aihe: Re: [gdal-dev] Re: srs definition for wgs84
I tried the following command , i guess I`m not getting the correct syntax here
regards,
Imran
parceldata.shp -skipfailures -lco SRID=4326 DIM=2 GEOMETRY_NAME=GEOM
-lnl TABLE_NAME_IN_ORACLE=Parcel1
On Thu, May 13, 2010 at 5:02 PM, Jukka Rahkonen
<jukka.rahkonen at mmmtike.fi> wrote:
> Peter J Halls <P.Halls <at> york.ac.uk> writes:
>> Imran,
>>     the Oracle SRID value of 8192 *is* WGS84.  Oracle does not store the EPSG
>> values, but has its own set.
> Starting from Oracle 10g or something it supports also EPSG codes. Old codes are
> still supported by Oracle but other programs usually do not understand Oracle
> SRID codes. Fortunately they are no more needed. But I think that the correct
> way to give target SRID with ogr Oracle driver is not to use -a_srs but the
> Layer Creation Option -lco SRID=4326.
> -Jukka Rahkonen-
> gdal-dev mailing list
I.R
