[gdal-dev] Re: Hoe to convert ERDAS imagine(.img) files to ARC info ASCII files viceversa
Imran Rajjad rajjad at gmail.com
Tue May 18 04:57:31 EDT 2010
hi,
Did you try ogr2ogr? it is also command line simple, I used it oftent
convert between different formats. After installing GDAL type >ogrinfo
/?  to see the possible formats.
regads,
Imran
2010/5/18 Iván Sánchez Ortega <ivan at sanchezortega.es>:
> El 18/05/2010 10:39, mail2vajram escribió:
>> I don't know how to use GDal_translate. Can u explain me how to do
>> this....
> You need to download the GDAL utilities, or some bundle that includes them
> (such as osgeo4w or fwtools).
> Then, open up a console and refer to the documentation:
> http://www.gdal.org/gdal_translate.html
> Cheers,
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I.R
