[gdal-dev] Re: Hoe to convert ERDAS imagine(.img) files to ARC
info ASCII files viceversa
Iván Sánchez Ortega
ivan at sanchezortega.es
Tue May 18 05:22:56 EDT 2010
El 18/05/2010 10:57, Imran Rajjad escribió:
> Did you try ogr2ogr? it is also command line simple, I used it oftent
> convert between different formats. After installing GDAL type>ogrinfo
> /? to see the possible formats.
OGR is for vector; GDAL is for raster. And Vajram is working with raster
files.
Iván Sánchez Ortega <ivan at sanchezortega.es>
