[gdal-dev] Unknown base item type : 4+error occurs when open a *.img file
Tue May 18 10:06:39 EDT 2010
mail2vajram wrote:
> When i am using the fillowing code i got the    error:Unknown base item type
> : 4
> DataSet ds=GDal.Open(".....\File1.IMG",Access.GA_ReadOnly);
> why this error ocuurs.........
> thank you.....
Vajram,
It means a node in the .img file has a BASEDATA object with an unknown data
type.  If things seem to be working ok anyways, then just ignore it and
continue on.  If not, you should consider filing a ticket and providing
the data with the ticket in some fashion.
Most likely the data is non-critical, but in at least some circumstances
the Python bindings are over sensitive to non-fatal errors issued down
deep in functions.
Best regards,
