Re: [gdal-dev] coordinate transformation with java library
Ivan Lucena
ivan.lucena at pmldnet.com
Wed May 19 08:55:59 EDT 2010
Ahmet,
Here is one example that you can find on GDAL source tree /swig/java/apps:
http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/java/apps/gdaltransformer.java
What OS are you using?
You can get the library from OSGeo4W [1] for Windows is that is the case.
Other alternative?
Geotools [2] or JTS Topology Suite [3] maybe, depending what you need, just coordinate transformation, data conversion, what kind of data, etc.
Regards,
[1] http://trac.osgeo.org/osgeo4w/
[2] http://geotools.org/
[3] http://www.vividsolutions.com/jts/jtshome.htm
> -------Original Message-------
> From: ahmet temiz <ahmettemiz88 at gmail.com>
> To: gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] coordinate transformation with java library
> Sent: May 19 '10 07:40
> hello
> I need to do coordinate transformation in my java application
> from UTM to geographic coordinates.
> Does gdal have any jar library that can do this transformation ?
> if there is
> whare can I find it ?
> What might be the other alternatives ?
> regards
> Ahmet Temiz
> Turkey
> gdal-dev mailing list
