[gdal-dev] coordinate transformation with java library
Frank Warmerdam
warmerdam at pobox.com
Wed May 19 09:01:18 EDT 2010
Ivan Lucena wrote:
> Other alternative?
> Geotools [2] or JTS Topology Suite [3] maybe, depending what you need, just coordinate transformation, data conversion, what kind of data, etc.
> Regards,
> [1] http://trac.osgeo.org/osgeo4w/
> [2] http://geotools.org/
> [3] http://www.vividsolutions.com/jts/jtshome.htm
I would add Proj4J - a new Java projections library:
http://trac.osgeo.org/proj4j/
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
