[gdal-dev] HowTo build MrSID plugin for CentOS 5?
Stephen Woodbridge
woodbri at swoodbridge.com
Tue May 25 19:36:04 EDT 2010
Nevermind, I just built gdal-1.6.3 from source with the Geo_DSDK which
is good enough for now. I need to move the sid files then I can start
working on them.
-Steve
Stephen Woodbridge wrote:
> Hi all,
> What is the best way to build gdal with MrSID support for CentOS 5?
> How does one tell if it is CentOS 5.2 or 5.3?
> The package manager installed:
> (1/6): gdal-devel-1.4.4-2.el5.rf.x86_64.rpm | 70 kB
> (2/6): geos-3.1.0-1.el5.rf.x86_64.rpm | 265 kB
> (3/6): unixODBC-2.2.11-7.1.x86_64.rpm | 835 kB
> (4/6): netcdf-3.6.3-1.el5.rf.x86_64.rpm | 991 kB
> (5/6): gdal-1.4.4-2.el5.rf.x86_64.rpm | 2.1 MB
> (6/6): geos-devel-3.1.0-1.el5.rf.x86_64.rpm | 4.8 MB
> Most of these from the DAG repository. In addition, I have downloaded:
> Lidar_DSDK-1.1.0.2814-linux.x86-64.gcc41.zip
> Geo_DSDK-7.0.0.2167.linux.x86-64.gcc41.tar.gz
> I'm not sure I need the Lidar file.
> I thought there was a nifty tool/script for building the MrSID driver as
> a plugin, but I can not fine it. I suppose I can build it all from
> source, but that makes deploying it to production systems a pain.
> Any help would be appreciated.
> Thanks,
> -Steve W
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
