[gdal-dev] Re: Getting private Metadata from Geotiff Images
Frank Warmerdam
warmerdam at pobox.com
Wed May 26 11:25:50 EDT 2010
radioheadCDA wrote:
> Thanks! That is a lot of help. Does that mean I can call the geotransform
> method to access the private metadata information?
Chris,
If you call GetGeotransform() you should get back six doubles which for
a north up affine georeferenced image (ie one specified with a single
tiepoint and a pixel scale) will contain the origin, and the pixel size.
I would encourage you to read the docs to understand the geotransform
fully.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
