[gdal-dev] S-57 Driver WRONG Geometry
Frank Warmerdam
warmerdam at pobox.com
Thu May 27 11:19:22 EDT 2010
Bogdan Grama wrote:
> Dear Frank
> Please find in the archive (http://www.wgs.ro/gdal/0_w.zip):
> -the ENC
> -GDAL Interpretation
> -correct Interpretation
> The assembled geometry is not according with specifications. Each
> referenced edge starts and ends with a ConnectedNode. Not all the
> Connected nodes are present in the feature geometry dump.
> This is not all. If the file is rendered with Sevencs
> (http://www.sevencs.com/service-products/download) and few others
> viewers the rendering is correct.
> For GDAL, ESRI FME, Caris the geometry is not correct.
Folks,
I have determined this is the same as the previously reported:
http://trac.osgeo.org/gdal/ticket/2147
for which I neglected to apply the patch. I have revised the patch
and applied it in trunk and 1.7 branch.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
