[gdal-dev] Howto change geo transform parameters in dataset.
Frank Warmerdam
warmerdam at pobox.com
Mon May 31 14:30:32 EDT 2010
Oliver Eichler wrote:
> Am 31.05.2010 19:13, schrieb Frank Warmerdam:
>>> Hi,
>>> I would like to change the offset of a referenced file. I use
>>> GDALDataset::GetGeoTransform(adfGeoTransform) to read the current
>>> settings. I change adfGeoTransform[0] and adfGeoTransform[3] and use
>>> GDALDataset::SetGeoTransform(adfGeoTransform) to replace the old
>>> settings.
>>> Of course that does not work. GDAL tells me that this works only on
>>> newly created datasets. Well ok. 2nd try:
>> Oliver,
>> What file format are you working with? Your approach is appropriate,
>> but not all drivers support changing metadata like the geotransform after
>> the file has been created on disk.
> Hi Frank,
> it's a GeoTiff. Is it possible with that format or should I have better
> have a look into the gdal_translate code?
Oliver,
Updating the geotransform should work in-place for GeoTIFF format. This
may be a relatively new feature. I will note that the file needs to be
open in update mode. So if opening an existing file use GA_Update as
the access mode.
Hmm, skimming the code back as far as 1.6 branch, the update of
geotransforms in geotiff seems to be supported. I will mention that
the "is only supported on newly created GeoTIFF files" message is
still generated for read-only files. I will correct this to a more
accurate message in trunk.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
