[gdal-dev] Howto change geo transform parameters in dataset.
Oliver Eichler
oliver.eichler at gmx.de
Mon May 31 15:18:37 EDT 2010
> Updating the geotransform should work in-place for GeoTIFF format. This
> may be a relatively new feature. I will note that the file needs to be
> open in update mode. So if opening an existing file use GA_Update as
> the access mode.
Arrgh, GA_Update! Stupid me. I was so focused on how to change the
offset that I forgot to check the obvious in GDALOpen first. Now it
works like a charm. Sorry for the fuzz.
Oliver
