[gdal-dev] dxf writer: specifying dash patterns with ogr-feature styles
Andreas Neumann a.neumann at carto.net
Mon Nov 1 07:01:00 EDT 2010
Hi again,
Another problem with the DXF writer:
I am trying to specify a dash-patterns for lwpolylines by using the
following OGR feature styling:
PEN(c:#FF0000,p:"2g,1g") - the pattern is defined in ground units, the
ground units in the data sets are set in meters.
In the resulting dxf I can see the line as red (as specified), but the
dash-pattern (dash of 2m and gap of 1m) does not appear.
Anyone knows on what may be wrong that the dash-pattern is not applied?
Thanks,
Andreas
Andreas Neumann
http://www.carto.net/neumann/
http://www.svgopen.org/
