[gdal-dev] Re: OCI: ogrinfo from normal table
lucvanlinden
luc.vanlinden at gmail.com
Mon Nov 15 12:29:29 EST 2010
I think you should remove the colon ";" at the end.
also put your sql between double quotes, this will help when should you use
literal strings as in:
"SELECT ... FROM ...WHERE name = 'your_name'"
Luc
View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdal-dev-OCI-ogrinfo-from-normal-table-tp5740283p5740683.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
