[gdal-dev] Re: OCI: ogrinfo from normal table
Sebastian E. Ovide sebastian.ovide at gmail.com
Mon Nov 15 12:57:17 EST 2010
great.... removing the colon ";" made the trick.. thanks
On Mon, Nov 15, 2010 at 5:29 PM, lucvanlinden <luc.vanlinden at gmail.com>wrote:
> I think you should remove the colon ";" at the end.
> also put your sql between double quotes, this will help when should you use
> literal strings as in:
> "SELECT ... FROM ...WHERE name = 'your_name'"
> Luc
> http://osgeo-org.1803224.n2.nabble.com/gdal-dev-OCI-ogrinfo-from-normal-table-tp5740283p5740683.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101115/3e885aea/attachment.html
