[gdal-dev] gdal and Solaris 10
sophia parafina
creta.kano at gmail.com
Tue Nov 16 13:43:55 EST 2010
Yes those files sounds right, but I haven't repackaged gdal in a couple of
years and I think I just grabbed all the libs and bin files and stuck them
into the appropriate directories. Good luck on your app.
sophia
On Tue, Nov 16, 2010 at 12:55 PM, Corrado, George P. <
George.Corrado at gd-ais.com> wrote:
> Great, Thanks a bunch Sophia. That article did the trick. It took a
> while for everything to compile, but once it was finished I ran the make
> install, and it looks like it created some files in the /usr/local/bin and
> /usr/local/lib directory’s.
> So now that I have my .so files, if I need to include them into my main Java project install, can I just take the files from /usr/local/lib ? I think the only files I need to take are libgdal.a, libgdal.la, libgdal.so, libgdal.so.1, and libgdal.so.1.14.3, unless there are some that you can think of. I know they need to be on the LD_LIBRARY_PATH, which I will do in my own install scripts. Oh and also copy the gdal binary files from /usr/local/bin.
> Anyway, this was a huge help to me, so thanks!
> George
> *From:* sophia parafina [mailto:creta.kano at gmail.com]
> *Sent:* Tuesday, November 16, 2010 10:22 AM
> *To:* Corrado, George P.
> *Subject:* Re: [gdal-dev] gdal and Solaris 10
> see http://trac.osgeo.org/gdal/ticket/3670
> On Tue, Nov 16, 2010 at 9:53 AM, Corrado, George P. <
> Ok, I've installed gcc and its dependences, but I can't figure out why I'm
> getting this error when I run make. Any ideas?
> make
> (cd port; make)
> make[1]: Entering directory `/export/gdal/gdal-1.7.3/port'
> /bin/sh /export/gdal/gdal-1.7.3/libtool --mode=compile --tag=CXX g++ -g -O2
> -Wall -DOGR_ENABLED -I/export/gdal/gdal-1.7.3/port -DHAVE_LIBZ -c
> -o cpl_conv.lo cpl_conv.cpp
> /export/gdal/gdal-1.7.3/libtool: syntax error at line 659:
> `func_arith_result=$' unexpected
> make[1]: *** [cpl_conv.lo] Error 2
> make[1]: Leaving directory `/export/gdal/gdal-1.7.3/port'
> make: *** [port-target] Error 2
> Thanks,
> George
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org [mailto:
> gdal-dev-bounces at lists.osgeo.org] On Behalf Of Corrado, George P.
> Sent: Tuesday, November 16, 2010 8:44 AM
> To: gdal-dev at lists.osgeo.org
> Subject: RE: [gdal-dev] gdal and Solaris 10
> Ok cool, yeah, I'm trying to build it on a Solaris 10 Sparc system now. I
> believe I'm using the Sun compilers as well. I'm guessing I can't just run
> the commands below without configuring a bunch of stuff?
> % cd gdal
> % ./configure
> % make
> % su
> Password: ********
> # make install
> # exit
> Thanks,
> George
> From: Peter J Halls [mailto:P.Halls at york.ac.uk]
> Sent: Tuesday, November 16, 2010 8:36 AM
> To: Corrado, George P.
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] gdal and Solaris 10
> George,
> Corrado, George P. wrote:
> > Does anyone know if gdal will work on Solaris 10, if so which of the
> prebuilt binaries can I use? Or do I have to build the binaries from
> scratch?
> Build from scratch is best. I've been running it on Solaris 10 / Sparc for
> years without problems. I do not know whether there may be any issues on
> Solaris 10 / Intel, but I do dot see why there should be any.
> My version is built using the Sun compilers.
> Best wishes,
> Peter
> > Thanks,
> > George
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Peter J Halls, GIS Advisor, University of York
> Telephone: 01904 323806 Fax: 01904 323740
> Snail mail: IT Services, University of York, Heslington, York YO10 5DD
> This message has the status of a private and personal communication
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101116/5c8cf4dc/attachment-0001.html
