[gdal-dev] Re: ImportError: No module named gdal
agisar
scott at agi.com
Tue Nov 16 15:34:50 EST 2010
I also was getting that import error and had to make sure that I was pointing
to the python included with FWTools. Then I got this:
File "gdal_merge.py", line 463, in ?
sys.exit(main())
File "gdal_merge.py", line 433, in main
if quiet == 0 and verbose == 0:
UnboundLocalError: local variable 'quiet' referenced before assignment
An output file is produced, but is all black. Export from OpenEV produces
the expected result.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdal-dev-ImportError-No-module-named-gdal-tp4721899p5745372.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
