[gdal-dev] Re: error compiling gdal 1.6.3 in rhel 5 64bits
javiricca
fjricca at gmail.com
Thu Nov 18 08:26:20 EST 2010
Hello Chaitanya,
I use this arguments:
./configure --without-ecw --with-png=internal --with-oci=yes \
--with-jpeg=internal --with-gif=internal --with-libz=internal
--with-libtiff=internal \
--with-geotiff=internal --with-perl --with-php --with-python
This configuration works in Centos 5.5 without problem.
Thanks
2010/11/18 Chaitanya kumar CH [via OSGeo.org] <
ml-node+5751537-2131365014-113114 at n2.nabble.com<ml-node%2B5751537-2131365014-113114 at n2.nabble.com>
> javiricca,
> Also, can you tell the command arguments you used for the configure script.
> On Thu, Nov 18, 2010 at 6:28 PM, Chaitanya kumar CH <chaitanya.ch<http://chaitanya.ch?by-user=t>
> @gmail.com <http://gmail.com?by-user=t>> wrote:
>> javiricca,
>> Check if you have 'php5-dev' package installed.
>> I too got similar (but not same) errors when it was not installed. While
>> you are doing that also check for 'php-config' package.
>> On Thu, Nov 18, 2010 at 1:55 PM, javiricca <[hidden email]<http://user/SendEmail.jtp?type=node&node=5751537&i=0>
>> > wrote:
>>> Hello,
>>> I'll trying to compile gdal in rhel 5 64 bits and I've getting some
>>> errors.
>>> gdal_wrap.cpp:1067: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1067: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1067: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1067: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1067: error: se trata la lista de expresiones initializer
>>> como
>>> una expresión compuesta
>>> gdal_wrap.cpp:1068: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1068: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1068: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1068: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1068: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:1069: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1069: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1070: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1070: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1070: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1070: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1070: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:1105: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1105: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1105: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1105: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1105: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:1106: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1106: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1106: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1106: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1106: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:1107: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1107: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1108: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1108: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1108: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1108: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1108: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:1120: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1120: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1120: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1120: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1120: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:1121: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1121: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1121: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1121: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1121: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:1122: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1122: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1123: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1123: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1123: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1123: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1123: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:1142: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1142: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1142: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1142: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1142: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:1143: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1143: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1143: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1143: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1143: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:1144: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1144: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1145: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1145: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1145: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1145: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1145: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:1468: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1468: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1468: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1468: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1468: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:1469: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1469: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1469: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1469: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1469: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:1470: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1470: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1471: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1471: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1471: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1471: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1471: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:1664: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1664: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1664: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1664: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1664: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:1665: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1665: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1665: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1665: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1665: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:1666: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1666: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1667: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1667: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1667: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1667: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1667: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:1706: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1706: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1706: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1706: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1706: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:1707: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1707: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1707: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1707: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1707: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:1708: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1708: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1709: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1709: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1709: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1709: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1709: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:1765: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1765: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1765: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1765: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1765: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:1766: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1766: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1766: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1766: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1766: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:1767: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1767: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1768: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:1768: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:1768: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:1768: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:1768: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:2022: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:2022: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:2022: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:2022: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:2022: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:2023: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:2023: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:2023: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:2023: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:2023: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:2024: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:2024: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:2025: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:2025: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> gdal_wrap.cpp:2025: error: expected primary-expression before ‘*’ token
>>> gdal_wrap.cpp:2025: error: ‘value’ no se declaró en este ámbito
>>> gdal_wrap.cpp:2025: error: se trata la lista de expresiones initializer
>>> como
>>> gdal_wrap.cpp:3596: error: redefinition of ‘pval
>>> _wrap_propget_MajorObject’
>>> gdal_wrap.cpp:1069: error: se declaró ‘pval _wrap_propget_MajorObject’
>>> previamente aquí
>>> gdal_wrap.cpp:3596: error: ‘zend_property_reference’ no se declaró en
>>> este
>>> ámbito
>>> gdal_wrap.cpp:3596: error: ‘property_reference’ no se declaró en este
>>> ámbito
>>> make[2]: *** [gdal_wrap.o] Error 1
>>> make[1]: *** [build] Error 2
>>> make: *** [swig-modules] Error 2
>>> How can I solve this problem? Is possible to solve it with another
>>> version
>>> of gdal or installing other libraries.
>>> Thanks in advance
>>> View this message in context:
>>> http://osgeo-org.1803224.n2.nabble.com/error-compiling-gdal-1-6-3-in-rhel-5-64bits-tp5750785p5750785.html<http://osgeo-org.1803224.n2.nabble.com/error-compiling-gdal-1-6-3-in-rhel-5-64bits-tp5750785p5750785.html?by-user=t>
>>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>>> gdal-dev mailing list
>>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5751537&i=1>
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Best regards,
>> Chaitanya kumar CH.
>> /tʃaɪθənjə/ /kʊmɑr/
>> +91-9494447584
>> 17.2416N 80.1426E
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5751537&i=2>
> View message @
> http://osgeo-org.1803224.n2.nabble.com/error-compiling-gdal-1-6-3-in-rhel-5-64bits-tp5750785p5751537.html
> To unsubscribe from error compiling gdal 1.6.3 in rhel 5 64bits, click
> here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5750785&code=ZmpyaWNjYUBnbWFpbC5jb218NTc1MDc4NXwxODk1MjMyMDA1>.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/error-compiling-gdal-1-6-3-in-rhel-5-64bits-tp5750785p5751610.html
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101118/d746034f/attachment-0001.html
