[gdal-dev] Re: Unable to load CIB datasets with GDAL
morabit b.morabito at tdnet.it
Mon Nov 22 04:20:23 EST 2010
I' ve just executed the nitfdump utility included in FwTools (GDAL 1.7.0)
against the nitf file
and for the complete file and for the truncated one I get the same report in
output:
Dump for 0AA43516_trunc.I42
File TREs: RPFHDR(48)
File Metadata:
  NITF_FHDR=NITF02.00
  NITF_CLEVEL=99
  NITF_STYPE=
  NITF_OSTAID=Ciga
  NITF_FDT=21050525212525
  NITF_FTITLE=0AA43516.I42
  NITF_FSCLAS=U
  NITF_FSCODE=
  NITF_FSCTLH=
  NITF_FSREL=
  NITF_FSCAUT=
  NITF_FSCTLN=
  NITF_FSDWNG=
  NITF_FSCOP=00000
  NITF_FSCPYS=00000
  NITF_ENCRYP=0
  NITF_ONAME=Datamat
  NITF_OPHONE=
Warning 1: Ignoring NITF RPF Location table since it seems to be corrupt.
Segment 1 (Type=IM):
  HeaderStart=466, HeaderSize=2130, DataStart=2596, DataSize=2425208
  DLVL=1, ALVL=0, LOC=C0,R0, CCS=C0,R0
Image Segment 0, 1536Px1536Lx1B x 8bits:
  PVTYPE=INT, IREP=MONO, ICAT=VIS, IMODE=B, IC=M4, COMRAT=0.75, ICORDS=G
  UL=(12.4447162504524,41.6429166666667), UR=(12.4630615273254,41.6498656351
  LL=(12.4447162504524,41.6359676981542), LR=(12.4630615273254,41.6429166666
  IDLVL=1, IALVL=0, ILOC R=0,C=0, IMAG=1.0
  6 x 6 blocks of size 256 x 256
  Image TREs: RPFIMG(1400)
  Band 1: IREPBAND=, ISUBCAT=, 217 LUT entries.
  Image Metadata:
    NITF_IID1=CIB
    NITF_IDATIM=21050525212525
    NITF_TGTID=
    NITF_ITITLE=0AA43516.I42
    NITF_ISCLAS=U
    NITF_ISCODE=
    NITF_ISCTLH=
    NITF_ISREL=
    NITF_ISCAUT=
    NITF_ISCTLN=
    NITF_ISDWNG=
    NITF_ISORCE=To be defined by the user
    NITF_PVTYPE=INT
    NITF_IREP=MONO
    NITF_ICAT=VIS
    NITF_ABPP=08
    NITF_PJUST=R
So I don't see the error you report in your post...
We hope that a solution to this issue can be found in a short time
as this is fondumental for our project.
Thank You
Best regards
Bruno
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Unable-to-load-CIB-datasets-with-GDAL-tp5756271p5762059.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
