[gdal-dev] Re: Unable to load CIB datasets with GDAL
Ryan McKinley
ryantxu at gmail.com
Mon Nov 22 19:54:10 EST 2010
This is the output I get for the file that fails to load: (semi redacted)
c:\data\RPF>nitfdump "F:\path\to\file.i24"
Dump for F:\path\to\file.i24
File TREs: RPFHDR(48)
File Metadata:
NITF_FHDR=NITF02.00
NITF_CLEVEL=03
NITF_STYPE=
NITF_OSTAID=TRIFID
NITF_FDT=11XXXXXX
NITF_FTITLE=file.I24
NITF_FSCLAS=U
NITF_FSCODE=DS
NITF_FSCTLH=
NITF_FSREL=
NITF_FSCAUT=
NITF_FSCTLN=
NITF_FSDWNG=
NITF_FSCOP=00000
NITF_FSCPYS=00000
NITF_ENCRYP=0
NITF_ONAME=TRIFID
NITF_OPHONE=
ERROR 1: Image header too small
Segment 1 (Type=IM):
HeaderStart=479, HeaderSize=2123, DataStart=2602, DataSize=286797
DLVL=-1, ALVL=-1, LOC=C-1,R-1, CCS=C-1,R-1
Segment 2 (Type=DE):
HeaderStart=289399, HeaderSize=209, DataStart=289608, DataSize=601
NITFAccessImage(0) failed!
c:\data\RPF>
thanks
ryan
On Mon, Nov 22, 2010 at 4:20 AM, morabit <b.morabito at tdnet.it> wrote:
> Hi,
> I' ve just executed the nitfdump utility included in FwTools (GDAL 1.7.0)
> against the nitf file
> and for the complete file and for the truncated one I get the same report in
> output:
> Dump for 0AA43516_trunc.I42
> File Metadata:
> NITF_FHDR=NITF02.00
> NITF_CLEVEL=99
> NITF_STYPE=
> NITF_OSTAID=Ciga
> NITF_FDT=21050525212525
> NITF_FTITLE=0AA43516.I42
> NITF_FSCLAS=U
> NITF_FSCODE=
> NITF_FSCTLH=
> NITF_FSREL=
> NITF_FSCAUT=
> NITF_FSCTLN=
> NITF_FSDWNG=
> NITF_FSCOP=00000
> NITF_FSCPYS=00000
> NITF_ENCRYP=0
> NITF_ONAME=Datamat
> NITF_OPHONE=
> Warning 1: Ignoring NITF RPF Location table since it seems to be corrupt.
> HeaderStart=466, HeaderSize=2130, DataStart=2596, DataSize=2425208
> DLVL=1, ALVL=0, LOC=C0,R0, CCS=C0,R0
> Image Segment 0, 1536Px1536Lx1B x 8bits:
> PVTYPE=INT, IREP=MONO, ICAT=VIS, IMODE=B, IC=M4, COMRAT=0.75, ICORDS=G
> UL=(12.4447162504524,41.6429166666667), UR=(12.4630615273254,41.6498656351
> LL=(12.4447162504524,41.6359676981542), LR=(12.4630615273254,41.6429166666
> IDLVL=1, IALVL=0, ILOC R=0,C=0, IMAG=1.0
> 6 x 6 blocks of size 256 x 256
> Image TREs: RPFIMG(1400)
> Band 1: IREPBAND=, ISUBCAT=, 217 LUT entries.
> Image Metadata:
> NITF_IID1=CIB
> NITF_IDATIM=21050525212525
> NITF_TGTID=
> NITF_ITITLE=0AA43516.I42
> NITF_ISCLAS=U
> NITF_ISCODE=
> NITF_ISCTLH=
> NITF_ISREL=
> NITF_ISCAUT=
> NITF_ISCTLN=
> NITF_ISDWNG=
> NITF_ISORCE=To be defined by the user
> NITF_PVTYPE=INT
> NITF_IREP=MONO
> NITF_ICAT=VIS
> NITF_ABPP=08
> NITF_PJUST=R
> So I don't see the error you report in your post...
> We hope that a solution to this issue can be found in a short time
> as this is fondumental for our project.
> Thank You
> Best regards
> Bruno
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Unable-to-load-CIB-datasets-with-GDAL-tp5756271p5762059.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
