[gdal-dev] Reprojecting a tiled dataset
Frank Warmerdam
warmerdam at pobox.com
Tue Nov 23 20:42:35 EST 2010
Stephen Woodbridge wrote:
> Hi Frank,
> Does this generate one 60GB output file or can it generate a new
> gdalwarp set of tiles with .vrt as output? This would be very cool!
Steve,
No, it produces one big internally tiled GeoTIFF file.
> So what would the gdalwarp command look like? something like:
> gdalwarp -t_srs EPSG:900913 -co TILED=YES -of GTiff -srcnodata 0
> -dstnodata 0 input.vrt outdir/output.vrt
Yes, something like that, though the nodata stuff likely isn't needed
if the source files are abutting tiles. also, the output is just a .tif.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
