[gdal-dev] GDAL contouring problem
Sun Nov 28 23:24:56 EST 2010
Ole Nielsen wrote:
> I am posting this again without test files attached due the 50K size
> limit. Anyone who wants to see them, please contact me directly.
> We have observed interesting anomaly with gdal_contour when one of the
> fixed levels is zero.
> If the zero contour is expressed as 0.0 (or indeed 0.0000) gdal_contour
> replies with the standard Usage message (see below). If the zero contour
> is expressed as the integer 0 (or 0.00000001) it works and produces the
> expected contours.
Ole,
The gdal_contour program has some rather hokey heuristics to try and
recognise the end of the list of contour levels.  The code looks like:
         else if( EQUAL(argv[i],"-fl") && i < argc-1 )
             while( i < argc-1
                    && nFixedLevelCount
                              < (int)(sizeof(adfFixedLevels)/sizeof(double))
                    && (atof(argv[i+1]) != 0 || EQUAL(argv[i+1],"0"))
                    && !EQUAL(argv[i+1], "-3d"))
                 adfFixedLevels[nFixedLevelCount++] = atof(argv[++i]);
So basically, it assumes everything is a "level" until something that
has a numeric value of 0 is encounter that isn't the specific string
"0".  So your analysis of the problem is essentially correct, but it is
more or less intentional as we try to support a list of levels with no
explicit "end of list" marker in the arguments to the command.
Best regards,
