[gdal-dev] GDAL contouring problem
Francis Markham
fmarkham at gmail.com
Mon Nov 29 00:48:56 EST 2010
Is there any reason not to include a heuristic that uses strtod() or
similar to test for the zeroness of the last argument?
-Francis Markham
On 29 November 2010 15:24, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Ole Nielsen wrote:
>> I am posting this again without test files attached due the 50K size
>> limit. Anyone who wants to see them, please contact me directly.
>> We have observed interesting anomaly with gdal_contour when one of the
>> fixed levels is zero.
>> If the zero contour is expressed as 0.0 (or indeed 0.0000) gdal_contour
>> replies with the standard Usage message (see below). If the zero contour is
>> expressed as the integer 0 (or 0.00000001) it works and produces the
>> expected contours.
> Ole,
> The gdal_contour program has some rather hokey heuristics to try and
> recognise the end of the list of contour levels. The code looks like:
> else if( EQUAL(argv[i],"-fl") && i < argc-1 )
> while( i < argc-1
> && nFixedLevelCount
> < (int)(sizeof(adfFixedLevels)/sizeof(double))
> && (atof(argv[i+1]) != 0 || EQUAL(argv[i+1],"0"))
> && !EQUAL(argv[i+1], "-3d"))
> adfFixedLevels[nFixedLevelCount++] = atof(argv[++i]);
> So basically, it assumes everything is a "level" until something that
> has a numeric value of 0 is encounter that isn't the specific string
> "0". So your analysis of the problem is essentially correct, but it is
> more or less intentional as we try to support a list of levels with no
> explicit "end of list" marker in the arguments to the command.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
