[gdal-dev] building with PDF driver on Windows + ?
Joaquim Luis
jluis at ualg.pt
Sun Oct 17 17:35:37 EDT 2010
Tamas,
I didn't notice that but on the other hand I never run it enough times
to make it happen.
Joaquim
> Hi poppler gurus,
> I've also compiled poppler.lib (version 0.14.4) with various versions
> of MSVC, but it seems to generate double free memory corruptions in gdal.
> A single run of pdf.py (from the autotest suite) seems to complete
> successfully, however running the script multiple times (in a batch)
> could eventually generate a crash. Has anyone run into the same issue?
> Best regards,
> Tamas
> 2010/10/17 Joaquim Luis <jluis at ualg.pt <mailto:jluis at ualg.pt>>
> On 17-10-2010 19:24, Brent Fraser wrote:
> Joaquim,
> Many thanks for the info. I may go the kde-win32 route for
> now to skip the building of poppler.lib, but I expect that
> eventually I may need to build it from source, especially for
> mapserver.
> Right, and
> >From memory, as I don't find the CMake cash with exact
> details.
> obviously I meant "cache" not "cash"
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101017/09a6b4ef/attachment-0001.html
