[gdal-dev] Reading GML
Ari Jolma ari.jolma at gmail.com
Wed Oct 20 06:08:19 EDT 2010
On 10/20/2010 12:15 PM, Paul Meems wrote:
> Hi all,
> I have a GML which I want to convert to shapefile.
> I've started with checking the file with ogrinfo (v1.7.2).
> It returns "Unrecognised geometry type <Surface>."
> After searching a bit it seems GDAL v1.8 might read the GML properly.
> So I'm looking for the binaries of GDAL v1.8. At Tamas his site I can
> download the v1.7.2 version but I can't find the v1.8 binaries.
> Does anybody know where I can download that version or do I need to
> build them myself?
Geoinformatica contains a very recent GDAL (1.8 is not yet released)
built for Windows with MinGW:
http://geoinformatics.tkk.fi/files/Geoinformatica/win32/Geoinformatica-2010-10-18.exe
It contains Xerces so GML should be supported (if that's a requirement -
I don't use GML much) - I have no idea if GML surfaces are supported.
Mark Overmeer develops a Perl module for GML but as of yet there's no
integration with Geoinformatica (which contains Perl support for GDAL).
Ari
> Thanks,
> Paul
> The Netherlands
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101020/d5dfaa4e/attachment.html
