[gdal-dev] Reading GML
Paul Meems
bontepaarden at gmail.com
Wed Oct 20 09:24:37 EDT 2010
Even,
You are completely right.
I was a bit confused by all the numbers in the package names ;)
I'm going the check my GML now.
Thanks,
Paul
2010/10/20 Even Rouault <even.rouault at mines-paris.org>
> Paul,
> you can find GDAL 1.8dev binary packages on Tamas site. They are identified
> as
> the -dev releases.
> Selon Chaitanya kumar CH <chaitanya.ch at gmail.com>:
> > Paul,
> > 1.7 doesn't support some geometry types that 1.8 does. GDAL1.8 is yet to
> be
> > released. You have to build it yourselves.
> > You can find a nightly snapshot of the source code for the trunk (1.8) at
> > http://trac.osgeo.org/gdal/wiki/DownloadSource#NightlySnapshots
> > Build hints: http://trac.osgeo.org/gdal/wiki/BuildHints
> > On Wed, Oct 20, 2010 at 2:45 PM, Paul Meems <bontepaarden at gmail.com>
> wrote:
> > > Hi all,
> > > I have a GML which I want to convert to shapefile.
> > > I've started with checking the file with ogrinfo (v1.7.2).
> > > It returns "Unrecognised geometry type <Surface>."
> > > After searching a bit it seems GDAL v1.8 might read the GML properly.
> > > So I'm looking for the binaries of GDAL v1.8. At Tamas his site I can
> > > download the v1.7.2 version but I can't find the v1.8 binaries.
> > > Does anybody know where I can download that version or do I need to
> build
> > > them myself?
> > > Thanks,
> > > Paul
> > > The Netherlands
> > > _______________________________________________
> > > gdal-dev mailing list
> > > gdal-dev at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > Best regards,
> > Chaitanya kumar CH.
> > /tʃaɪθənjə/ /kʊmɑr/
> > +91-9494447584
> > 17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101020/8afced7c/attachment.html
