[gdal-dev] Reading GML
Even Rouault
even.rouault at mines-paris.org
Wed Oct 20 07:20:04 EDT 2010
Paul,
you can find GDAL 1.8dev binary packages on Tamas site. They are identified as
the -dev releases.
Selon Chaitanya kumar CH <chaitanya.ch at gmail.com>:
> Paul,
> 1.7 doesn't support some geometry types that 1.8 does. GDAL1.8 is yet to be
> released. You have to build it yourselves.
> You can find a nightly snapshot of the source code for the trunk (1.8) at
> http://trac.osgeo.org/gdal/wiki/DownloadSource#NightlySnapshots
> Build hints: http://trac.osgeo.org/gdal/wiki/BuildHints
> On Wed, Oct 20, 2010 at 2:45 PM, Paul Meems <bontepaarden at gmail.com> wrote:
> > Hi all,
> > I have a GML which I want to convert to shapefile.
> > I've started with checking the file with ogrinfo (v1.7.2).
> > It returns "Unrecognised geometry type <Surface>."
> > After searching a bit it seems GDAL v1.8 might read the GML properly.
> > So I'm looking for the binaries of GDAL v1.8. At Tamas his site I can
> > download the v1.7.2 version but I can't find the v1.8 binaries.
> > Does anybody know where I can download that version or do I need to build
> > them myself?
> > Thanks,
> > Paul
> > The Netherlands
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
> /tÊaɪθÉnjÉ/ /kÊmÉr/
> +91-9494447584
> 17.2416N 80.1426E
