[gdal-dev] problems to cut form large image
Frank Warmerdam
warmerdam at pobox.com
Fri Oct 22 13:30:38 EDT 2010
Jan Tappenbeck wrote:
> hi !
> i want to cut a part of a lage (7gb) tiff-image and use this command:
> C:\Program Files (x86)\FWTools2.4.7>gdalwarp -r near -te 2608000
> 55900100 2613104.5424 5582270.5709 -of GTiff -o F:\wt_3a.tif
> D:\weissenturm\streifen_3_GK2.tif
> but i get following message:
> did anybody now anything about this message ??
Jan,
The problem is the -o switch you use - there is no such switch.
Perhaps you mean to indicate the output file? The gdalwarp command
normally ends with the input file, then the output file.
eg.
gdalwarp <various options> in.tif out.tif
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
