[gdal-dev] GDAL rejecting Winkel Tripel projection
William Kyngesburye
woklist at kyngchaos.com
Fri Oct 22 15:50:59 EDT 2010
Using gdalwarp and ogr2ogr with:
-t_srs '+proj=wintri'
I get:
Translating source or target SRS failed:
+proj=wintri
and:
Failed to process SRS definition: +proj=wintri
respectively.
Other proj-style SRS definitions work, but not wintri. It works directly with the proj program.
Is GDAL blocking use of wintri, or not configured to use it?
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
