[gdal-dev] GDAL rejecting Winkel Tripel projection
Even Rouault
even.rouault at mines-paris.org
Fri Oct 22 16:07:12 EDT 2010
apparently, the OGRSpatialReference object has currently no support for this
projection.
Le vendredi 22 octobre 2010 21:50:59, William Kyngesburye a écrit :
> Using gdalwarp and ogr2ogr with:
> -t_srs '+proj=wintri'
> I get:
> Translating source or target SRS failed:
> +proj=wintri
> and:
> Failed to process SRS definition: +proj=wintri
> respectively.
> Other proj-style SRS definitions work, but not wintri. It works directly
> with the proj program.
> Is GDAL blocking use of wintri, or not configured to use it?
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
