[gdal-dev] OGR2OGR S57
pcreso at pcreso.com
Fri Oct 22 14:59:59 EDT 2010
Hi Tim,
S57 is a pretty complex format, so I suggest you look at an intermediate format that is supported by some sort of data management capability so you can work with it & select what is to converted to kml.
Postgis is the obvious one, or you could use shapefiles with ogr & something like QGIS to work with your dataset to select the features you are after.
ogr has limited selection/query capanbility, but I'm not sure how well supported this is for S57 data input.
HTH,
Brent Wood
--- On Fri, 10/22/10, timg <timg at boatinghowto.com> wrote:
> From: timg <timg at boatinghowto.com>
> Subject: [gdal-dev] OGR2OGR S57
> To: gdal-dev at lists.osgeo.org
> Date: Friday, October 22, 2010, 7:20 PM
> I am new to this so pardon me if I ask a stupid
> question. I have
> successfully used the ogr utility to convert an s57 ENC to
> kml format for
> overlay on google earth. So now I have a google earth
> layer with a
> bazillion yellow pushpins...haha. So My question...Is
> it possible to use
> ogr to just pull out a specific layer from the s57 and make
> that layer a kml
> file, and if so is it possible to pull out more than one
> layer at a time?
> I looked at the ogr2ogr commands but can't figure out how
> to do this, if it
> can be done would you please give me an example command to
> enter into the
> shell.
> my source file is master.000 and the kml file will be
> 099.kml
> thank you
> Tim
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/OGR2OGR-S57-tp5661459p5661459.html
> Sent from the GDAL - Dev mailing list archive at
> Nabble.com.
> gdal-dev mailing list
