[gdal-dev] GDAL rejecting Winkel Tripel projection
Even Rouault even.rouault at mines-paris.org
Fri Oct 22 17:02:40 EDT 2010
Le vendredi 22 octobre 2010 22:48:43, William Kyngesburye a écrit :
> So, why?  Is it because it has no defined inverse projection?  I think
> aitoff is another such, and it's not handled by GDAL either.
I don't know the reason. My guess is that perhaps beause nobody cared enough
about that projection to add support for it ??
> I see a +wktext option mentioned in ogr_srs_proj4.cpp:importFromProj4(),
> but it doesn't help.  I guess importFromProj4() looks at the projection
> and rejects the proj4 string before +wktext is helpful.
+wktext cannot help when OSR doesn't recognize the projection. It only helps
to keep the extra options that OSR doesn't handle by itself.
> If I could figure out a WKT definition, does GDAL restrict that?
> Any other way I can get GDAL to use wintri?
You can write the WKT and add a EXTENSION['PROJ4','+proj=wintri ...'] node in
it, so it is used when translating it into proj4.
> On Oct 22, 2010, at 3:07 PM, Even Rouault wrote:
> > apparently, the OGRSpatialReference object has currently no support for
> > this projection.
> > Le vendredi 22 octobre 2010 21:50:59, William Kyngesburye a écrit :
> >> Using gdalwarp and ogr2ogr with:
> >> -t_srs '+proj=wintri'
> >> I get:
> >> Translating source or target SRS failed:
> >> +proj=wintri
> >> and:
> >> Failed to process SRS definition: +proj=wintri
> >> respectively.
> >> Other proj-style SRS definitions work, but not wintri.  It works
> >> directly with the proj program.
> >> Is GDAL blocking use of wintri, or not configured to use it?
> >> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> >> http://www.kyngchaos.com/
> >> All generalizations are dangerous, even this one.
> >> _______________________________________________
> >> gdal-dev mailing list
> >> gdal-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> "Mon Dieu! but they are all alike.  Cheating, murdering, lying, fighting,
> and all for things that the beasts of the jungle would not deign to
> possess - money to purchase the effeminate pleasures of weaklings.  And
> yet withal bound down by silly customs that make them slaves to their
> unhappy lot while firm in the belief that they be the lords of creation
> enjoying the only real pleasures of existence....
> - the wisdom of Tarzan
