[gdal-dev] GDAL rejecting Winkel Tripel projection
William Kyngesburye woklist at kyngchaos.com
Fri Oct 22 18:23:45 EDT 2010
On Oct 22, 2010, at 4:02 PM, Even Rouault wrote:
>> If I could figure out a WKT definition, does GDAL restrict that?
>> Any other way I can get GDAL to use wintri?
> You can write the WKT and add a EXTENSION['PROJ4','+proj=wintri ...'] node in
> it, so it is used when translating it into proj4.
I'll give it a try, thanks.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Mon Dieu! but they are all alike.  Cheating, murdering, lying, fighting, and all for things that the beasts of the jungle would not deign to possess - money to purchase the effeminate pleasures of weaklings.  And yet withal bound down by silly customs that make them slaves to their unhappy lot while firm in the belief that they be the lords of creation enjoying the only real pleasures of existence....
- the wisdom of Tarzan
