[gdal-dev] problem with the OGR VRT example?
Even Rouault
even.rouault at mines-paris.org
Tue Oct 26 13:24:28 EDT 2010
Works for me (tested with 1.7.2, but there's no reason 1.7.1 doesn't work).
Check that <OGRVRTDataSource> is on the first line of the test.vrt file without
any extra character (space, newline, etc...) before.
Le mardi 26 octobre 2010 18:19:44, John Cartwright a écrit :
> Hello All,
> I was looking at the OGR VRT example on
> http://www.gdal.org/ogr/drv_csv.html, and it doesn't seem to work -
> complains that unrecognized driver. Am I missing something?
> Following example on http://www.gdal.org/ogr/drv_csv.html,
> 1) created a text file (test.csv) with the following:
> Latitude,Longitude,Name
> 48.1,0.25,"First point"
> 49.2,1.1,"Second point"
> 47.5,0.75,"Third point"
> 2) created a text file (test.vrt) with the following:
> <OGRVRTDataSource>
> <OGRVRTLayer name="test">
> <SrcDataSource>test.csv</SrcDataSource>
> <GeometryType>wkbPoint</GeometryType>
> <LayerSRS>WGS84</LayerSRS>
> <GeometryField encoding="PointFromColumns" x="Longitude"
> y="Latitude"/> </OGRVRTLayer>
> </OGRVRTDataSource>
> 3) tried "ogrinfo -ro -al test.vrt" and got:
> FAILURE:
> Unable to open datasource `test.vrt' with the following drivers.
> This is GDAL 1.7.1 on linux. My ultimate objective is that take a CSV
> file whose first two fields are x,y and convert to a shapefile with the
> remaining fields as attributes.
> Thanks!
> --john
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
