[gdal-dev] Re: warp, translate and world files
Paul Meems
bontepaarden at gmail.com
Wed Oct 27 04:32:37 EDT 2010
Hermann,
You're right the size difference is because of PNG8 or PNG24.
I'm now on the gdal_warp track again. But I can't produce a PNG file. When I
use -ot PNG I get this list of supported file formats:
VRT: Virtual Raster
GTiff: GeoTIFF
NITF: National Imagery Transmission Format
HFA: Erdas Imagine Images (.img)
ELAS: ELAS
MEM: In Memory Raster
BMP: MS Windows Device Independent Bitmap
PCIDSK: PCIDSK Database File
ILWIS: ILWIS Raster Map
SGI: SGI Image File Format 1.0
Leveller: Leveller heightfield
Terragen: Terragen heightfield
ERS: ERMapper .ers Labelled
JP2ECW: ERMapper JPEG2000
RMF: Raster Matrix Format
RST: Idrisi Raster A.1
INGR: Intergraph Raster
GSBG: Golden Software Binary Grid (.grd)
PNM: Portable Pixmap Format (netpbm)
ENVI: ENVI .hdr Labelled
EHdr: ESRI .hdr Labelled
PAux: PCI .aux Labelled
MFF: Vexcel MFF Raster
MFF2: Vexcel MFF2 (HKV) Raster
BT: VTP .bt (Binary Terrain) 1.3 Format
IDA: Image Data and Analysis
ADRG: ARC Digitized Raster Graphics
SAGA: SAGA GIS Binary Grid (.sdat)
Does this mean I haven't build my GDAL properly? If not can you give me a
hint on how to enable png support in the make files?
Thanks,
Paul
2010/10/26 Hermann Peifer <peifer at gmx.eu>
> On 25/10/2010 11:17, Paul Meems wrote:
>> Hi list,
>> I've got several png files with worldfiles.
>> I need them in another projection (28992 --> 3785).
>> I'm using gdalwarp to reproject to a tiff file and then I use
>> gdal_translate to create a png file again.
>> My original png file is about 25 kB, the warped tiff is over 2MB and the
>> translated png file is over 80 kB.
> I am not quite sure why you don't use -of png to save the creation of the
> intermediate tiff file. You might also be able to use -of byte which creates
> an 8 bit PNG (if this format is sufficient for your purpose).
> The size difference 20k vs 80k could be due to the fact that the source
> file is PNG8 and the generated file is PNG24. There may be other reasons,
> though.
> Hermann
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101027/16847495/attachment.html
