[gdal-dev] NoData vs metadata confusion
Oyvind Idland
oyvind.idland at gmail.com
Thu Oct 28 07:18:59 EDT 2010
Thanks for fast reply !
I assume the IMAGE__NO_DATA_VALUE=255,255,255 comes from the MrSid SDK
library.
These values could easily be mapped to the GDAL-bands NoData, as they
practically means
the same ? (255 for each band)
-- Oyvind
On Thu, Oct 28, 2010 at 1:09 PM, Chaitanya kumar CH
<chaitanya.ch at gmail.com>wrote:
> Oyvind,
> GDAL handles nodata values band by band, whereas in MrSID all the bands of
> the particular pixel location must match the nodata values for that pixel to
> be considered nodata.
> Currently nodata values are ignored in this driver. I don't know if
> anything is planned for future releases.
> On Thu, Oct 28, 2010 at 4:21 PM, Oyvind Idland <oyvind.idland at gmail.com>wrote:
>> Hello,
>> stumbled across a problem when reading MrSid:
>> The MrSid dataset contains 3 bands, R/G/B. None of the 3 bands gives me a
>> GetNoDataValue(),
>> however, the metadata contains IMAGE__NO_DATA_VALUE=255,255,255.
>> Does this mean, that I have to check for both cases ?
>> The version is GDAL 1.7.2.
>> Regards,
>> Oyvind Idland
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101028/5915ccca/attachment-0001.html
